Hemp Seed Oil from the Czech Republic is Unique, Say the Exp
Puffin13
Post by Puffin13 »
Hemp Seed Oil from the Czech Republic is Unique, Say the Experts CANNADERM uses hemp
August 10, 2010 /EIN Presswire/ -- CANNADERM uses hemp seed oil pressed in cold in protective atmosphere as the main ingredient, containing a precious complex of bioactive substances with favourable effects on human health.
Hemp seed oil contains barely any ballast substances or proteins and also habit-forming psychoactive substances like THC. Hemp oil is pressed from approved varieties of hemp, which is cultivated in a special manner to contain the absolute minimum of these components. CANNADERM hemp oil in bio-quality is recommended to complement the nutrition of children and adults, being suitable for vegetarians and vegans.
Use of CANNADERM products for complementary care in the treatment of a series of skin disorders is recommended by physicians and experts in alternative medicine and healthy lifestyle.
In Central Europe, has CANNADERM products become part of every pharmacy and shops selling natural products, says the owner of WebStore cannabis-cosmetics.com, Mr. M.Bjacek.
"It helps the immunity system in cases of cancer, it alleviates pains after chemotherapy. It contains vitamins A, B, C, D, E, K series and has the highest content of amino acids and fatty acids. It decreases the serum homocysteine, cholesterol and blood pressure. It cleans kidneys, improves cataracts. Cannabis oil supports corrects the function of heart, veins, brain and cleans the blood circulatory system. Great for the joints and backbone," says the leading Czech pharmacologist professor Jan Svihovec,
In the cosmetic practice we can use the oil to treat dry, dehydrated and sensitive skin, when it helps as a nourishing component of the skin. Hemp oil contains in considerable amounts also vitamin B and B1 (the second one being contained in significant quantity), and therefore it is recommended as a nourishing component of the after-sun preparations.
Robatko-sun lotion with SPF 30 | Cannabis-cosmetics.com.
It also contains high quantity of y-tocofer. Anti-carcinogenic effect of the oil is also important.
Hemp cosmetics make use of positive properties of hemp, which, thanks to bacterial and regenerative effects, is irreplaceable, especially in the fight against skin disorders. Skin treatment - skin affected by psoriasis, eczema, acne | Cannabis-cosmetics.com
What is so different in the hemp seed oil compared to other oils used in cosmetics?
"Hemp seed oil is ideal for the cosmetic purposes; it contains a balanced ratio of precious unsaturated fatty acids and natural antioxidants, it is further hypoallergenic and penetrates very well to the skin, does not create only occlusive film on the top layer," explains Ivana Kostkova, MD. from the department of dermatovenerology in Prague 10. "Thanks to this property the unsaturated fatty acids and other components can penetrate in deeper layers of the skin and thus influence the cell properties directly and immediately. Hemp seed oil has, thanks to its properties, really a positive effect on the condition and function of the human skin, being able to harmonize the condition of skin cells, efficiently balance the water, lipid and pH balance of the skin and contributes also to regeneration of protective skin coat, thus increasing the overall resistance of the skin against negative external effects," adds MD Kostkova.
Source & links
Cannabis is The Tree of Life
