True, however, if you can fully cover them (so they have complete darkness), for flowering purposes, then the answer is YES you can get some good smoke. However, this usually requires a fairly elaborate setup.You'll be pushing it time wise to get them to bud to full maturity, I reckon you'll need 16 weeks to flower them.
If you are "gueriila" growing (i.e. simply growing outdoors, in the woods, without any type of artificial darkness), then I would bet that they won't mature in time.
I'd say 16 weeks is on the far end of the flowering time estimate. I would expect about 11-14 weeks flowering time, from my experience growing Jamaican weed and other pure-ish sativas.
When does the first frost typically hit your area? When does the daytime sunshine go to 12 hours or less? These two things can help you to determine if or when you would be able to get them to maturity. If your autumns are fairly dry, then that will also help. On the other hand, if your autumns are fairly wet then, even an airy sativa could be subject to severe bud rot.
Also, as has been mentioned, if they are Jamaican plants, then they will stretch to a large height, so you may want to pinch then or FIM them to keep the size down and/or have more bud sights.
