GLASS BLUNT
smokestaxlitenin
GLASS BLUNT
Post by smokestaxlitenin »
has anyone tried this new item? picked one up last night...large size can hold a couple grams of bud...great for concerts...no refilling needed.... 8)
Puffin13
Re: GLASS BLUNT
Post by Puffin13 »
smokestaxlitenin wrote:has anyone tried this new item? picked one up last night...large size can hold a couple grams of bud...great for concerts...no refilling needed.... 8)
Sounds killer. Got a pic or link?
Cannabis is The Tree of Life
Tell us more please!
all i could find was these?
http://www.chunkyglasspipes.com/glass-blunts.html
cantona7
Post by cantona7 »
as far as iv seen they are basically a tube shaped glass pipe. you fill the tube with the weed and it smokes like a blunt/joint.
instagram @shooter_mcdabbin
smokestaxlitenin
cantona7 wrote:as far as iv seen they are basically a tube shaped glass pipe. you fill the tube with the weed and it smokes like a blunt/joint.
not quite C7....its a tube within a tube....the mouthpiece-tube slides back & forth into the main chamber, which gets filled with the bud. the mouthpiece pulls out or goes in for filling any quantity you desire, up to about an eighth. as you smoke up, you push the mouthpiece up to exit the ash and keep smoking fresh bud down until all gone. ...take one hit, it goes out, unless you keep a puffin and re-light as needed. just eliminates the hassle of re-fill. was only 25$...the link above is exactly what i'm talking about.....peace. gotta go get that morning buzz on...oh yeah, i already did :D
PirateRaff
Post by PirateRaff »
so its kinda basically an advanced chillum
If your pee is clean you are a cop!
ATWA
Post by ATWA »
PirateRaff wrote:so its kinda basically an advanced chillum
i dont think so.
u dont fill a chillum with weed and just smoke like a cigarr.
chillum is another technique
Air Trees Water & Animals
smokestaxlitenin
i dont think so.
chillum involves the whole hand cup movement for proper smoking....
these glass blunts smoke like a joint. real smooth. :D
cheese
Post by cheese »
they look like they would fit into a bong. or is that just the mouthpiece
' Smoke em if you got em '
bluedream
i think it works like this...
Post by bluedream »
cheese, I'm not sure what the pic you are trying to post is. That looks like a female piece extender or something.
My understanding of a glass blunt, is that is simply that. A decently thick piece of glass, shaped like a cigar, with a hollowed out barrel down the middle. You fill the middle with bud, much like how bud would be in the middle of a traditional blunt such as a swisher sweet, philly, or dutch master. You light the end of the blunt, like you are starting a real blunt, and the glass blunt will keep the bud inside "cherried" so it smokes just like a traditional blunt.
go to prettylightsmusic.net
smokestaxlitenin
bluedream(love that bud)...not exactly...there is another component to the equation...
besides the large hollow chamber, there is a glass mouthpiece/tube that inserts into the mouthside of the chamber, which slides back & forth and allows you to push out the ash end...it also allows you to fill as much or little as you'd like.... 8)
