vulcano
Rand Mcnally
vulcano
Hi,
I`ll be in netherlands in mid octouber and I would like to buy a volcano vaporizer, where I should look for one? What is better the easy or solid valve system?
Thanks
Thanks
Rand Mcnally
Rand Mcnally
- ed the head
- Location: New Amsterdam of my mind and of my making. Trips:3, Haj:14
As another forum visitor responded, get it on line. I got one for my home 115 60hz US and it's great. It's not a Volcano, but it was 1/2 the price. It's basically a precision glass bowl on top of a cylinder that contains a heating element and a fan. You just set the temp and wait for the green light. It came with two means of inhaling. One is a mouth valve release balloon that you can fill using a precision high tempered glass attachment. It also come with a glass mouthpiece on the end of a long surgical tube on a precision high tempered glass attachment. This is what I use.
http://www.vaporoutlet.com/extreme_vaporizer.html
You can use an AC converter like this one
http://www.dvdoverseas.com/store/index. ... og6_0.html
This one is US$17 for 100 watts, which is more than enough for this vaporizor.
Rand Mcnally
Hi, 220v is no problem my house has bouth 110 and 220v the problem is the frequency ( http://en.wikipedia.org/wiki/Utility_frequency ) and this can`t be changed by a AC converter like ed the head sugested because it can only change the power from 110 to 220 or 220 to 110 and europe uses 220v/50hz and here is 220v/60hz
- ed the head
I see.Rand Mcnally wrote:Hi, 220v is no problem my house has bouth 110 and 220v the problem is the frequency ( http://en.wikipedia.org/wiki/Utility_frequency ) and this can`t be changed by a AC converter like ed the head sugested because it can only change the power from 110 to 220 or 220 to 110 and europe uses 220v/50hz and here is 220v/60hz
I've asked if this or other units perform a 60-60 hz and 50-60 Hz conversions and if I get a reply back I will post it.
Reading your link, I believe the conversion device must also convert the Hz back and forth between 50 and 60 as required. It would have to in order to function as advertised.
Best of luck in either event.
ed the head wrote:What is the Hz tolerance of this unit please?
100W Deluxe Voltage Converter with Two Outets 220V<->110V
We have a 220 60 Hz. 220 feed to convert to 110 60 hz. , is this within the specs of this unit?
