The Hash Making Thread
Moderator: Balou
Any other hasj makers out there? I use one of Mila's "Bubbleators" It works fine and has produced lots of fine crystals. The problem is foam! Does anyone know of a foam abater (organic and safe of course) or a method for getting rid of foam other than endless spraying with water or skimming?
There is no time like right now.
i dont get this part?
what i do is after using bags
put hash on cardbord//break up the chunks of hash (so it dries faster)then once dry // start pressing it wit my presser
and put in in the dark cold place for few days
by then its nice and hard chunk of hash
NEVER leave water in your hash cause its will turn moledy « witch aint good for ya!
if your using bubble bag why would you want to wet it more?method for getting rid of foam other than endless spraying with water or skimming?
- metal4mullets
Geezer wrote:Sooo? Neither of you guys get any foam when making hash? That was the only question. I spray the bag to remove the foam, more water does not hurt the hash, it drains right through.
Peace
Kermit wrote:Patience with bags!!
Bubble B-Quicktakes the effort out!
Yeh and there is your answers x2
Get a honeybee extractor.metal4mullets wrote:I've always wanted to make hash but it seems like too much effort and/or it's too expensive.
Like usual, I'll most likely just end up making cannabutter *shrug*.
http://www.cannabisculture.com/articles/3083.html
I fail to see the answer to the foam issue. If you're not getting a foam build up you're doing something wrong. I have been using a "Bubbleator" from Mila's Pollinator shop for years. I am not a newbie to making hash. I make several ounces per month. I am just looking for ideas for reducing the foam. If you don't know, don't get foam or are an amateur hash maker please don't bother replying. Thanks.Kermit wrote:Geezer wrote:Sooo? Neither of you guys get any foam when making hash? That was the only question. I spray the bag to remove the foam, more water does not hurt the hash, it drains right through.
PeaceKermit wrote:Patience with bags!!
