Hash
dan1986ccfc
Hash
Post by dan1986ccfc »
I remember last time I went to the 'Dam I had a hard time using it. Here in the UK we burn hash and crumble it into joints.. Or that used to be the case anyway!
From what I have seen on the forum you roll the hash into a line and then place it straight into the joint? Does that really smoke!?
Do you do this with all kinds of hash?
Are there any other ways to smoke it?
Thanks in advance for any answers!
Dan
Bilbo Baggins
Post by Bilbo Baggins »
You can only roll a snake with plasticine type soft hash, some of the best hashes are brick hard, some will crumble into powder, the most common way to put hash into a joint is to simply heat the hash with a lighter --then it should crumble into the joint---definately worth a try though, if youve never smoked hash before then you're in for a treat
Good hash doesn't need heating.
wietroker
Post by wietroker »
Black (hand pressed) hash you can roll into a skinny if you want.
Maroc hash is harder but you don't need to burn most of it at all. The nicest Marocs look a bit like shit when you crumble them. Some Marocs are hard (not necessarily poor quality) and a little heat can help. Hand heat is usually enough but I do occasionally use a quick flame.
But nothing like holding a lighter to UK soapbar stuff for ten seconds and getting two seconds where you can crumble up and burn your thumb at the same time. :D :D
Carlos
Post by Carlos »
some will need a brief flash of a lighter but most you will be able to pick apart
dan1986ccfc
brilliant, cheers.
Will bear these answers in mind
looking forward to a nice bud/hash spliff
tdw121270
Post by tdw121270 »
95% of the hash in holland is soft. There are hard hashes out their, but it's all a matter of preference. I prefer the softer hashes Nepalese Temple Ball being my fav. Also when Im wasted it's easier for me to roll a couple of hash sausages then to burn the hash and my fingers in the process :P .
Next trip 1st August 2015. 2 weeks camping/putting my feet up.
cantona7
Post by cantona7 »
only hash iv had in the dam that was to hard was some red leb i got at prix d'ami.
instagram @shooter_mcdabbin
damtoker
Post by damtoker »
cantona7 wrote:only hash iv had in the dam that was to hard was some red leb i got at prix d'ami.
I got some of that from Katsu and a quick flame was required - good stuff though.
The turkish was quite hard from Paradox but again, a very quick heat was all that was needed :)
Certainly nothing like commercial UK solid though :lol:
templeball
Post by templeball »
IMHO I think sausage hash is awful because it tends to burn unevenly along one edge all the way down in my experience, hence you can end up ruining a well rolled joint...cant beat tiny tiny little pieces, the bigger the pieces the bigger the burn holes in your t-shirts/chest hairs/favourite shirt/sofa :shock:
In the land of the blind, the one-eyed man is King
Bug
Post by Bug »
templeball wrote:IMHO I think sausage hash is awful because it tends to burn unevenly along one edge all the way down in my experience, hence you can end up ruining a well rolled joint...cant beat tiny tiny little pieces, the bigger the pieces the bigger the burn holes in your t-shirts/chest hairs/favourite shirt/sofa :shock:
I have so many holes in my favorit t-shirt :cry:
Carlos
Post by Carlos »
I've got the inevitable pinhole burns
All down the front of my favorite satin shirt
Marco
Post by Marco »
Or on your skin!
If you really want to taste the hash, pick up a cheapie pipe and smoke it straight up.
smokestaxlitenin
Post by smokestaxlitenin »
Pipe it, baby...take a little chunk and throw it in a small glass bowl and get a pure deep hit that will have you comin back for more! I find that when i mix it with weed, you don't get the true effects. sometimes, you must mix for ease of smoking. such as the grey mist crystals, stix gunpowder, etc...but even those can go straight into a bowl that has a fine screen....well, at least thats what i'll be doing in another month or so. :D
