Arizer Extreme Q
spidergawd
Re: Arizer Extreme Q
Post by spidergawd »
ZBeebs wrote:You have to make sure the screen is clear, then pack the elbow, and turn the temps up since the bud is further from the heating element. I also think this works best with the whip, not bags.
The herb needs to be finely ground and loose for the air to pass through hence the size of the herb chamber and the twizzle stick. I think :?.
Happy highs folks :D :D
Panog
Post by Panog »
Hey guys I'm planning on buying a vaporizer and this beauty seems perfect when I read your post...
I think I'll use a lot more the bags than the whip so is it as good with bags ?
BigRigRob
Post by BigRigRob »
I found the "stock" bag that came with it kinda small, so as mentioned here, I rigged up a turkey oven bag. This porridge was just right. Image
matty223
Post by matty223 »
mine just came in the mail, what temp are you using i tried 175c 185c and in between
I usually stick with 185 for the first couple then maybe crank it up 5
matty223
Post by matty223 »
cool, thanks cisco
jimi62471
Post by jimi62471 »
let me know how that works out Matty, been looking into the vaporizer method myself.. ( uses much less product, better delivery method)
Living The Dream...
BigRigRob
Post by BigRigRob »
You'll enjoy your new toy Matty, I sure enjoy mine. Between the Extreme Q & my pipes by Tia (http://www.pipesbytia.com/ shameless plug 8) ) I have to mark a date on the calender to "dust off" the old Lux perc. Image
Panog
Post by Panog »
My extrem Q is sent :) can't wait to get it !
^^ in regard to yer earlier question , the bag is all I use :mrgreen: as others have pointed out you can get (or use Turkey ones) bigger bags
Enjoy I'm sure you will :mrgreen:
Panog
Post by Panog »
Haha I'm sure I will too, gonna get wasted between the vape and our latest batch of BHO (I think you saw it on instagram :))
Panog
Post by Panog »
Received it this morning but I had to go to work :( will try it tonight :D
StonedSince67
Post by StonedSince67 »
Panog wrote:Received it this morning but I had to go to work :( will try it tonight :D
nice one panog, i hope you enjoy the unit
i have had my arizer extreme q for three months and just love it, it gives all of the potency and taste and none of the by-products of combustion
what i have read in a book about vapourising
1. the range for vapourisation of the thc cannabinoid is 180 celsius to 200c
2. the range for combustion of the herbal material is 230c to 235c
what i was told last january by the budtender at paradox
1. you only need about 0.1 gram of material for a good smoke
2. when a new variety of weed comes into the shop, he starts by vapping a little to check out how it tastes
what i was told last january by a customer at paradox
1. the vapour of the thc cannabinoid is clear
2. the thc starts to vapourise at 180c
3. for a smoke a setting of 185c is a reasonable compromise between not-too-cool and not-too-hot
4. the temperature for the vapourisation of the cbd/cbn/etc cannabinoids is 220c
what i do in practice
1. i put in from 0.1 gram to 0.3g of herbal material, lately i have been putting in about half a bowl-full to try to stop the airflow creating a small donut of the material with a hole in the centre
2. i start at 180c
3. after the run of vapour starts to diminish i take the bowl and elbow off the unit (watch out it's hot!!!) and putting it on a ceramic surface i give it a little stir and replace for another run of vapour
4. maybe i'll give it another stir if i have something really nice and there is a lot of vapour at 180c
5. finally i will up the temperature setting by 5c to 185c and repeat the cycle of smoke-stir-smoke-stir
6. depending upon what i have in the bowl and how desperate i am for a stone i might stir and go up another 5c to 190c
7. by then or earlier the material will be exhausted and should be a light brown chocolate shade
i don't have definitive confirming references for most of this information, so any comments about what i might have right and what i might have wrong would be appreciated, after all i am here to learn
a possible slogan
smoke vapour, not smoke
Panog
Post by Panog »
This stuff is bomb lol, shared 2 .1g bags (and I got 2 bags about of .1g !) and I'm really high, it works as good if not better than the volcano I tried in the dam
godhed
Post by godhed »
I've been using one for almost 3 years. I only use oven bags, heat at 200C for 15 minutes before using fan at 3 (high) setting and prefer to use coarsely ground fresh buds in mixtures of 3 or 4 strains. This really blows my mind. :!: :?: :idea:
