cake
theonenonly
cake
Can i grind up 1g of hash and just mix it with
http://groceries.asda.com/asda-estore/s ... tid=296610
Will that work instead of making cannabutter?
Thanks
Thanks
theonenonly
That's a lot of Hash, a half an ounce! Usually, an 1/8 oz of good weed is plenty for one box of brownie mix. The amount of Hash needed would Depend on the potency, and If you cook it with oil first: I think that you could get by with at least half of that.cisco wrote:Think you will need more than 1G to go in your mix though dude ? i eat 2.4 G in a yoghurt not long ago and was not that mashed , i would do a 1/2 oz in a brownie mix
Not really how many pieces of brownie to you get maybe 12 ? jus over a G each not alot at all ! i just dont get buzzed on small amounts that are used for cakes etc in Dam .2 .5 etcCal X wrote:That's a lot of Hash, a half an ounce! Usually, an 1/8 oz of good weed is plenty for one box of brownie mix. The amount of Hash needed would Depend on the potency, and If you cook it with oil first: I think that you could get by with at least half of that.cisco wrote:Think you will need more than 1G to go in your mix though dude ? i eat 2.4 G in a yoghurt not long ago and was not that mashed , i would do a 1/2 oz in a brownie mix
With you there Cisco. I stopped buying/eating space cakes about four years ago, was a waste of money on me. Never even felt a slight buzz. Probably would be different using larger portions, 2gms per piece might do the trick. Something else for me to experiment with once I get my grow op going again.cisco wrote:Not really how many pieces of brownie to you get maybe 12 ? jus over a G each not alot at all ! i just dont get buzzed on small amounts that are used for cakes etc in Dam .2 .5 etcCal X wrote:That's a lot of Hash, a half an ounce! Usually, an 1/8 oz of good weed is plenty for one box of brownie mix. The amount of Hash needed would Depend on the potency, and If you cook it with oil first: I think that you could get by with at least half of that.cisco wrote:Think you will need more than 1G to go in your mix though dude ? i eat 2.4 G in a yoghurt not long ago and was not that mashed , i would do a 1/2 oz in a brownie mix
You could be right Cisco, I have never tried using Hash for brownies. That would be a pretty expensive pan of brownies though! I agree with you about the potency of Space Cakes, they didn't do much to me either!cisco wrote:Not really how many pieces of brownie to you get maybe 12 ? jus over a G each not alot at all ! i just dont get buzzed on small amounts that are used for cakes etc in Dam .2 .5 etcCal X wrote:That's a lot of Hash, a half an ounce! Usually, an 1/8 oz of good weed is plenty for one box of brownie mix. The amount of Hash needed would Depend on the potency, and If you cook it with oil first: I think that you could get by with at least half of that.cisco wrote:Think you will need more than 1G to go in your mix though dude ? i eat 2.4 G in a yoghurt not long ago and was not that mashed , i would do a 1/2 oz in a brownie mix
- templeball
Ive succesfully made hash brownies and cookies and hash hot chocs for years and its very straightforward thankfully. I have high (very high actually) resistance and 2g of ok hash would wipe me out in a high fat milk hot choc, or 2 times that for a tray of cookies/brownies enough for 2-3 people. If none of you are experienced then take half first, wait half an hour at least before the next bit etc, just till you do it a few times and know what you are comfortable with
The main thing is not so much how good the hash is, but how efficiently you get it absorbed by the body, and that needs fat, which allows the psyhcoactive compounds to be easily absorbed. So to the post above about yoghurt not working, its no surprise as there probably wasnt enough fat present in the yoghurt so you could double the amount of hash and still not get ripped.
The brownie mixes that use oil and eggs are good, double the fat content basically and easy, make sure you use loads of normal hot choc powder, not an instant just add hot water one, and only use blue full fat milk. Soften the hash first (i use the oven on a very low temp), then crumble it in very finely whatever you are making, dont have big fat lumps as they may never break down. I stir and stir the hot choc in the pan until the milk boils (you have already added the hot choc powder, you want the fat from that working alongside the milk), it tastes gross but within 20 mins you should start to get ripples and you may be flat out after a few hours.
Personally i wouldnt use soap bar hash under any circumstances, there is so much nasty shit in there and you really dont want that in your body
In terms of brutal efficiency I think hot choc followed by choc chip packet mixes are the best, with brownies last. Lastly I put over 7g in a brownie mix once and microwaved it, 7 people in a room all sat there for hours waiting for a buzz that never came, so dont even bother using the microwave, it just solidifies the hash
In the land of the blind, the one-eyed man is King
theonenonly
Thanks for the tips.
I just made a batch of cookies with 1g.
I crushed the hash up into fine powder and put it in the cookie mix (275g enough to make 6 small cookies) then i added the butter (25g) and kneeded together.
Baked for 12 mins and left to cool.
The wife ate 2 of her cookies 40mins ago and is now giggling like mad and pausing inbetween her words lmfao! I ate 2 of mine 20mins ago and still waiting......
Dont think the wife needs more than the 2 so if I dont feel anything within the next hour i'll have the other 2
- templeball
cool, live reporting of a hash cookie evening!theonenonly wrote:Thanks for the tips.
Have fun
- templeball
