Veg tent set up (coco dripper) help please
bigs
Post by bigs »
high all
right, so i have 8 x blue cheese, and 2 x bagseed, 3 weeks from seed currently in my room under a 600w.. everything going pretty well, nice bushy growth...so hopefully they ll come down just before xmas.
When I turn these into flower I want to set up a veg room, thus having a 2 month harvest cycle + mother plants for cuttings.
Not needed for another 6 weeks or so, so I am looking to get prepared and put a budget to one side
I also want to be able to propergate from seed in this tent, so ideally I would like floor space for a small propergator.
So i was thinking a drs 80 tent, 200w blue lamp, cheap extract fan. Any suggestions? The space itself is small, perhaps 90cm x 120 cm, 2m tall.
In terms of media, I want to swap over to a coco dripper (perhaps wilma system).
So, I will need two set ups - one for my veg room, many small plants as possible, and a 8 or 10 pot for my flowering room. Any suggestions on systems to use? I was thinking of finding a small pot (under 6l) drip system for the veg, and then a wilma for the flower room.
Thanks, enjoy your weekend all :D
Prestoned
Post by Prestoned »
One option is to use the DR80 on the side. I never veg my plants that tall (I LST them to keep them small). I use T5s to veg in there so I can get maximum height for the bush.
A DR80 on its side would be 80cm tall, 80cm wide, with 160cm of floor space. I can fit 8 comfortably in there.
For the propagator, I just shove mine in the corner, allowing it to absorb any indirect light. I used to have a DR60 on its side for clones and keeping the mother alive and the DR80 as the veg tent.
Am a soil man, so I say the best 'system' to use is your hand and a watering jug. I tried setting up an auto feeding system, but was very fidly. Couldnt get all the tubes to fit securley. Feeding only takes 8-16 minutes every other day for me. Sometimes longer if I stare at the girls :D
bigs
Post by bigs »
Prestoned wrote:One option is to use the DR80 on the side. I never veg my plants that tall (I LST them to keep them small). I use T5s to veg in there so I can get maximum height for the bush.
thanks. you've thrown a spanner in the works as your sideways idea is very interesting... although i need to find more floor space.. was planning to use a room thats only 90cmx 120ish floor space.
Prestoned
Post by Prestoned »
A DR80 the right way up should still be enough floor space (depending upon pot size). Just means about half the vertical space wont be used.
A friend has a 400w HPS in his DR80, and its on his side! Crazy
Midzy
Post by Midzy »
Would it work if you link up the exhaust port on the veg tent to the inlet port of yer F tent, and then the big exhaust fan would draw in air to the veg tent as well, would this save costs on running 2 fans and also less noise.
I have never had any tent experience so I dunno but in theory it should? :)
Prestoned
Post by Prestoned »
Theory seems good, cant confirm tho.
My veg tent is 40-50%+ humidity, so I would use fresh outside air to keep the humidity down.
