Spliff amounts
- TwoCanucks
SGawain235
Iko wrote:gixxer wrote:likewise, but always mixed with tobacco, prob 50% of eachBoner wrote:You know I've had and used everything like bongs and vapes and I always go back to a good old fashioned spliff.
joint from a gram, 4![]()
That really is a crime.
Yeah, I can't talk much smack myself. I've been thinking of going to a cigar shop and get one of these fat cigars called a "Churchill" and make a spliff out of that for my UK friends. I am not sure how many grams will end in that monster but I'm pretty sure the answer will be "many".
Did you think you'd get rid of me that easily?
SGawain235
Well, it's kindof complicated. Here, let's go to the board.Boner wrote:Do you weigh it out before rolling a joint?cantona7 wrote:.8-1.2 for me
Edit: What happens if you put .7 or 1.3 in, does it go horribly wrong?
If you look here you will see the "substoner spliff field" that if you don't very carefully regulate the cannabis-spliff ratio there are dire consequences for the space-time continuum.
I'm suprised you didn't learn this at the Stoner Academy.
- cantona7
actually yea i do weigh it. funds have been tight between $1400 a quarter for tuition, gas, etc as well as saving most of my funds for my next trip. had i not rationed my last ounce would not have lasted the month i needed it to.Boner wrote:Do you weigh it out before rolling a joint?cantona7 wrote:.8-1.2 for me
instagram @shooter_mcdabbin
This thread reminded me of the biggest joint I have ever seen smoked. Years ago I worked in Sudan with a well known contractor with mainly Irish employees. The local grass, though probably shit by today's standards, only cost pennies and it was great to see previously staid and anti " drug " types adopt a more tolerant attitude to the weed in the absence of running tap alcohol.
Anyway. I remember one such convert stuffing a 200 cigarette empty carton with grass, making holes at both ends and puffing away. I don't think he added tobacco.
My mate weighs every joint think he uses .4cantona7 wrote:actually yea i do weigh it. funds have been tight between $1400 a quarter for tuition, gas, etc as well as saving most of my funds for my next trip. had i not rationed my last ounce would not have lasted the month i needed it to.Boner wrote:Do you weigh it out before rolling a joint?cantona7 wrote:.8-1.2 for me
Edit: What happens if you put .7 or 1.3 in, does it go horribly wrong?so i go .8 for a regular joint and 1.0 or 1.2 tops if i had a really bad day and pretty much just wanna forget about it and veg out watching espn.
- Trichome_Dense
I just break a gram in two, and that's 2 scoobs. Always reverse roll, never make L's. Sometimes I make an extra long scoob (two rizlas in length) by using 3 rizlas, one bent double and licked for the gum only - this scoob will also be reverse rolled (mean feat
). A full gram would go into long scoob...
I love bongs, but don't have one... don't think vapes are all that, I'm always left feeling like I need another hit with a vape.
So, 0.5 in a scoob, always make 2 ... my sig expalins why
... as long as it aint a cheque
- truckerclart
good description on the folded rizla,been long time since i did the fold trick but,for me its kingsize skins with 0.5-1 gram depending on mood,and a bit of a cig to keep goingTrichome_Dense wrote:I just break a gram in two, and that's 2 scoobs. Always reverse roll, never make L's. Sometimes I make an extra long scoob (two rizlas in length) by using 3 rizlas, one bent double and licked for the gum only - this scoob will also be reverse rolled (mean feat). A full gram would go into long scoob...
here i am ,a friendly trucker just passing thru
- puffpuffgive
when i'm a home, generally 0.2g small silver skins with a little drum baccy.Rather 4 little ones than 1 big one
when i'm in dam, 0.5-1g per spliff again with a pinch of drum.
ik hou van amsterdam
