EC Meters..
Bob2
EC Meters..
Post by Bob2 »
so i want to buy a ec meter (£20ish im cheap) but i would prefer to self calibrate it myself, any ideas??? and is it important for it to do TDS..
thanks for any advice and help .
stu..
bigs
Re: EC Meters..
Post by bigs »
are you sure you need one?
If you are using out the bottle nutes (and can follow instructions), in coco or soil you'll be fine without. In my opinion they are only needed if you are mixing up ur own shit or growing hydro....
Re: EC Meters..
^^ Agreed a PH meter yeah but as Bigs says unless yer doing hydro ? And I'm thinking £20 may not be enough for a decent one ? The bluelab truncheon thing comes highly recommended :wink:
Lol in fact is cf meter is the same as ec ? (Bluelab is a nutrient (cf) truncheon) :oops: :lol:
Bob2
Re: EC Meters..
Post by Bob2 »
cheers guys..
speedy
Re: EC Meters..
Post by speedy »
ec/cf is the only true scale,
ec stands for electrical conductivity,
it works by sending out a small electrical signal into the solution,
because water is not actually a very good conductor of electricity, its only the minerals within it that are,
it calculates the strength of the solution by seeing how much of the current it sent out, comes back.
tds and ppm are calculated directly from ec, however depending on which company makes them it could be 500x 640x or 700x the ec level.
Colina
Re: EC Meters..
Post by Colina »
Cisco wrote:The bluelab truncheon thing comes highly recommended :wink:
Truncheon is the way to go ;-)
HOLLAND
Re: EC Meters..
Essential for use with chemical fertilizers especially when your using extras on top of your base nutrient, takes you to another level of control over your plants, you can also get your nute levels pretty spot on as yer tap water will already get the little beast flashing without nutes.
IMHO makes it easier, had my truncheon years, the only thing i never sold off but it was freebie from the wholesalers back when they was £39 a pop.
Dont bother with organics though, virtually useless, add any organic boosters when you have your setting for your chemmys correct. 8)
Soz boner had to have a post
