Vaping through glass how do you do it ?
I'm sure I seen peeps using their Arizer Extreme connected to their bongs on YouTube , ?! But I can't seem to find it !! Done a search with no luck (I will try different key words)
does anyone know how to go about it ? Cheers
ZBeebs
Re: Vaping through glass how do you do it ?
Post by ZBeebs »
you use the whip with a glass L-bend on both ends...one goes on the cyclone bowl on top of the Arizer, the other in the glass fitting on the bong, provided your bong has an 18mm joint.
my advice is to pull slowly through the bong for thicker hits.
Thanks Zbeebs very informative :wink:
