rooting gel
rooting gel
i have been using clonex for a while now but it seems to take at least 2-3 weeks to get any roots through im looking to try something diferent and was wondering if anyone had any sugestions on anything i can try as an alternative
cheers in advance
i fucking love amsterdam !!!!!!!!!
Re: rooting gel
Pretty sure I read clonex was just a nutrient and didn't have any actual cloning chemicals in it, if you're in the UK then your local garden centre should have some, I use some organic stuff it stinks fucking horrible but it works, you'll probably already know this but try and clone off newer branches any older ones can and will take ages to root.
Re: rooting gel
Iv heard bad things about clonex , any time I took cuttings I jus left them to root in a vase of water and they would take about 7-14 days .
sam
- Location: 6 Trips for a total of 65 Days in the Netherlands
Re: rooting gel
Clonex is not just a nutrient. There are 2 main rooting hormones Indole-3-butyric acid and naphthaleneacetic acid and clonex uses the first one. USBL which one does Olivias use? I would bet that Clonex causes problems from one or more of its other ingredients and not the rooting hormone.Boner wrote:Pretty sure I read clonex was just a nutrient and didn't have any actual cloning chemicals in it, if you're in the UK then your local garden centre should have some, I use some organic stuff it stinks fucking horrible but it works, you'll probably already know this but try and clone off newer branches any older ones can and will take ages to root.
Re: rooting gel
I would be very wary of using anything that says, "Not for edibles" on the label. Maybe it's not a problem if the product is smoked, but why take the chance?
Re: rooting gel
cheers for all the replies went to the local grow shop and all they sell is clonex so i went to the garden centre and got some of the organic stuff
fuck me i nearly threw up there and then hope it works better than it smells
then like a fucking idiot got in the car and had a smellBoner wrote:I use some organic stuff it stinks fucking horrible but it works
- Bilbo Baggins
Re: rooting gel
Stuff I've got just now is Clonex and I have to agree--Its just not good enough Ive had a few failures with it. cheap rooting powder you bought from any garden centre done the job, maybe time to get back to the simple methods.
Re: rooting gel
order olivias gel,you wont regret,i dont lose anything anymore...wheres some wood
Re: rooting gel
Or, as Cisco said, just use water.
My friend bought an airstone/pump, a window box and a swimming float, and roots cuttings with the minimum of fuss. They don't need to be kept humid and they can be quite large too.
Re: rooting gel
Re: rooting gel
If anyone finds Olivia's in the UK can you ship one to Labrotary Cisco for when the experiments resume
