Niacin
Just eat healthy and drink plenty of water...... your body should metabolize completely in 21 days.
Fruit, veg and wholefoods are good, oats, porridge, museli etc.
One thing though, I presume this is for a test?
You can't get rid of the waste products in your hair and nails.............
When the going gets weird, the weird get going!
- lee1escape
You can pluck your hair and cut your nails, but will take a long time before they are all clean. You urine should be good atm, tho. When is your test? Drink lots of water, cranberry juice, vinegar-water, and eat lotsa roughage. Will any of these things purge your system faster? Dunno. THC is stored in the fat cells of your body, and release at a fixed rate. All you can really do is try to help your body purge the blood as fast as it can.marcw84 wrote: there is no way to get it out of my hair and nails? or does it just take a long time
50 characters? Nothing to say in 50 characters.
cannibistourist
run and workout a lot along with a healthy diet will get it out niacin helps but you get enough in fruits and vegetables naturally. taking a pill will just make yer skin burn! if you know the date you can use a detox shampoo but i have heard mixed reviews of those. leave the vineger alone but cranberry juice is good for ya anyway so go head and drink that. green tea is a great natural diuretic (sp) so drink a few glasses a day to make you piss more but be sure and drink plenty a water.
and never ever give the testers your first piss of the day!!!
its to damn hot out!
these guys covered it pretty well i just wanna add some thing about this
I've read countless times that THC is outta the system in 3-4 wks, even for heavy smokers. I found out first hand that that is NOT always the case.....i am a big (read fat) guy and heavy daily smoker and it took over 6 wks for me to piss clean. This was with taking a small niacin supplement every other day and drinking 1 gal + of water a day and cranberry juice when i wasn't drinking water. Needless to say i was gettin nervouse at week 4 and 5 of dirty pee.....alls well that ends well.your body should metabolize completely in 21 days.
self test kits:
In the U.S. kits can be purchased from drugstores which are commercially marketed.
However, many of the "head shops" (bongs, papers, whatever) sell for usually under five dollars kits which are apparently the same type that testing labs use. It's not wrapped in a fancy package, it's just a dip strip/card with instructions.
I have used the latter, it's a good indicator of where you stand. I abstained for a couple of weeks and then started the "purge" overnight, drinking more fluids than I could stand, doing the same in the morning, then testing myself.
I tested clean after two weeks doing this. There are some more sophisticated tests which test for creatinine levels and some other things. If you can get yourself testing clean without having to drink gallons of water I think you're better off.
Substitute if you can, purge and take multivitamins the day of test to put some color back in if you can't. B vitamins will put the "golden sheen" in the mix :-)
the test isn't until the first week of december. i've been clean for 3 weeks this saturday already. i've been drinking loads of water and cranberry juice, started an excellent exercise routine, and heavily increased my fruits and vegetables. i don't know about niacin. my buddy is a pharmacist and he says that niacin is bad for your liver?
Best thing to do is not to consume any more THC until after the test.
if its a urine test, drink as much water as humanly possible for about 12 hours before the test.
Dont give them the first piss of the day, and never the first or last bit of a piss, as this will contain the most toxins.
thats what I did anyway and came back clean
When all else fails and you need something quick, try this web site, http://www.cleartest.com
They have a product called Synthetic Urine Substitute, works EVERYTIME. If you get an unexpected call and have to take a p-test that day, use it. I've had to use it twice, results came back negative, also had family and friends use it, always works.
