Darkness
Slip & Sal
Darkness
Post by Slip & Sal »
At the end does everyone give their plants a darkness period before cutting? People have told me anything from 1 to 4 days. I don't know or think it matters. Do others think it creates more thc or more taste? Does anyone think it is bad?
Panog
Re: Darkness
Post by Panog »
I tried to do it once and didn't see anything different
Slip & Sal
Re: Darkness
That's what I was thinking
Panog
Re: Darkness
Post by Panog »
But I don't know everything, if people do this there must be a reason
Re: Darkness
Post by AzLaker »
I do. I give my plants around 24 to 36 hours of darkness before cutting them down. Suppose to increase the resin levels. Not really sure if it helps or not, but it doesn't hurt the plants any as far as I can see.
Slip & Sal
Re: Darkness
In the past i felt it lessened the smell? any thoughts?
thefreeland
Re: Darkness
Post by thefreeland »
Hello to all, :mrgreen:
Yes the period of black gives a production of trichomes in more and a better aroma.....
But 4 days are too much can for this aroma and production of trichomes suplémentaires
I have to try 10 in 14days in the black and I assure you that the aroma will more be pronounced than the meme origin(stump) without period of black.
On the other hand, new production of trichomes thus effects more sativa given that this trichomes is young (high effect) and thus not amber (effect stone)
Cordially.
GROW & SMOKE :mrgreen:
Slip & Sal
Re: Darkness
sorry I didn't get that
Re: Darkness
Post by AzLaker »
+1 :? :?
thefreeland
Re: Darkness
sorry but i speak and Write badly English, I use a translator "Reverso" to translate my texts of the french in English....
What you do not understand please?
(in french):
→ Période de NOIR complet en fin de floraison
La technique consiste à laisser la plante durant une semaine (minimum) à deux semaines (maximum), je préconise une dizaine de jours, dans le noir. Idéalement, cela doit être accompagnée d'une baisse de température.
Ceci aura pour effet d'augmenter la taille et le nombre de trichomes, et donc d'accroître la production de résine. De plus, cela permet d'entamer la dégradation de la chlorophylle, et de la transformer en sucres.
Ces effets sont amplifiés par une période de sécheresse (au niveau de l'air, voire également de l'eau), de quelques jours, en toute fin de flo.
NB : Durant ces 10 jours, la plante continue à mûrir. Il est possible, et même vivement recommander, de procéder au rinçage durant cette période.
Voici un exemple concret :
la flo est à J +60, et vous estimez que les buds seront prêtes dans une à deux semaines. Vous avez donc ce laps de temps pour effectuer le rinçage (qui devrait même avoir débuté depuis au moins 72 heures pour une meilleure efficacité), ainsi que mettre en application cette technique de période de noir en fin de flo.
Cette période de noir commencera quand les trichomes seront à 80% laiteux et 20% ambrés, ce qui donnera approximativement 50/50 en fin de cycle.
1) à J +55 vous avez commencé la phase de rinçage,
2) à partir J +60, et jusqu'à la récolte, vous laissez les plantes dans l'obscurité ( * )
3) A partir de J +68 vous cessez d'arroser,
4) A J +70 vous récoltez !
(source : guide cannaweed) :arrow: :?
Attention : cette technique favorise aussi l'apparition de moisissure sur les têtes (Oïdium), ainsi, toute la production peu être détruite en quelques jours ! Il faut donc maintenir un taux d'humidité au plus bas.
