vapo-bowl
nala2991
vapo-bowl
Post by nala2991 »
Heyoo
I was just wondering if anyone had any experiences with the vapo-bowl. If you have used this bowl before could you be so kind to give your opinion on it. What are the pros and cons, how easy it is to use, and how to avoid combustion and what type of lighter to use. BTW has anyone seen the vapo-bowl (glass) in any headshops in Amsterdam (not online shops).
All relevant replies are greatly appreciated!
spireax
Re: vapo-bowl
Post by spireax »
I've got a vapor star, which I think is a similar thing. Pretty easy to use, can combust like you say, takes a quite a bit of heat before it does though, and you soon learn how to not make smoke. A bit of practice and a good bit of coughing when you push it that hit too far :lol:
Normal pipe lighters work ok, don't need a jet flame, could probably use them hemp wicks and avoid breathing in butane.
Azarius used to stock them in mokum, but depends if they've finished renovating yet.
In conclusion - gets you high :wink:
