Amazed Pipe
- redeyezman
Amazed Pipe
Well the Journey pipe fellow taking to long to get stock available so I'm going withthis "Amazed Pipe" Seems to be generally the same concept of having longer smoke path to help cool the smoke. I will review more when she arrives in the post.
Shells sink. Dreams float.
Re: Amazed Pipe
http://www.youtube.com/watch?v=AoYUuZg2lx4redeyezman wrote:Well the Journey pipe fellow taking to long to get stock available so I'm going withthis "Amazed Pipe" Seems to be generally the same concept of having longer smoke path to help cool the smoke. I will review more when she arrives in the post.
Never seen this before - mine has just been ordered...
- redeyezman
Re: Amazed Pipe
Ha! fits right in your bong! Didn't see this video, but pretty cool "extra feature" ...Only saw the promo video here:obligon wrote:http://www.youtube.com/watch?v=AoYUuZg2lx4redeyezman wrote:Well the Journey pipe fellow taking to long to get stock available so I'm going withthis "Amazed Pipe" Seems to be generally the same concept of having longer smoke path to help cool the smoke. I will review more when she arrives in the post.
http://youtu.be/CM95VbJDlRI
Re: Amazed Pipe
Really like that. Very nifty
- redeyezman
Re: Amazed Pipe
REVIEW:
It works fucking great! Plenty of tar near start of "320mm path" and basically NONE at the end. Gradually less tar from start to end, so you can really see "how well it works."
I won't say the smoke is as cool as a bong, but easily the coolest smoke to come from a pipe I have ever used. I think this would help keep bongs cleaner, longer too if used in lieu of a stem. Those are usually the most fragile part anyhow.
The end you load your gear is in is deceptively small, and will hold plenty. A nice size nug, ground up easily fit.
There is a screen in the end you put your gear in. On the "main body" portion of the 3 total pieces. I don't recall seeing this mention on the manufacture page ( http://www.red-eye.co.uk/ ) and that is really the only reason I mention it. If you ever need to replace it you'd have to cut to size.
Will post an update upon first cleaning. Just planning on doing q-tip + alcohol.
Re: Amazed Pipe
Just looked.
They look useful for a quick smoke.
Is there anything they need though, like gauze etc?
And how many hits do you get off a bud?
- redeyezman
Re: Amazed Pipe
No nothing extra is needed other than some good gear. Those replicas might be ok if saving some money is your goal, but I like the stainless steel model I got.
- redeyezman
Re: Amazed Pipe
After about 10 days of daily use, (2.5g) she needs to be cleaned. Thinking about unscrewing it and storing in alcohol between uses. Any other owners have bright idea on keeping clean?
Also stock screen got a hole after about 14 or 21 grams. Now i gotta chase for screens....fuck
Re: Amazed Pipe
just ordered one of these.
looking forward to trying it out.
did you find an easy method for cleaning it?
- redeyezman
Re: Amazed Pipe
Yeah. Just put salt and rubbing alcohol in a glass jar, and shake for a few minutes. Comes out looking, and smoking like brand new. Enjoy!
worldcitizen1723
Re: Amazed Pipe
That's where the journey pipe wins out... It's screenless! And really really simple to clean!
After almost a year of use... I appreciate it even more!
Re: Amazed Pipe
worldcitizen1723 wrote:That's where the journey pipe wins out... It's screenless! And really really simple to clean!
how are your magnets? mine is still going strong too
