Hi mate
The MFLB is a decent vape for the price but I'm not sure if its the ideal vape for your situation
I find the LB great for stealth situations, such as in a bar or in the cinema (when you need a quick hit no one knows about)..
I don't ever use my launch box at home, simply because there are other vapes that are more designed for home use and in turn produce thicker, stronger clouds of vapor
I'd say if you got LB for home use it would do the job fine but i think before long (if you got quite into vaping) you would be craving bigger lungfuls of vapor and I could imagine soon enough you buying a home unit to go along with your launch box..
For that reason I'd recommend an extreme Q or a Da Buddah vape .. both are slightly more expensive then a LB but they are more designed for having a vape session at home rather then a quick sneaky toke like the LB.. Either of those are great starter vapes
I used to have an extreme Q as my first vape but upon doing more research i realized there are vapes that are more efficient .. I soon moved onto a log type vape.. Log vapes take 30min to heat up but you can leave them on all the time and just come back to them when you want to use them.. Personally if i was in your position i would save going through a few different vapes and go with a log vape simply because they are very efficient (Run off very little weed) and also due to their simplicity .. There are a few different companies that make log vapes (See links at bottom of this) i personally went with an underdog..
Below is a video to explain underdog log vapes
http://www.youtube.com/watch?v=K70w377NaxM
Here are a few links to different manufacturers of log vapes:
http://fuckcombustion.com/threads/wychw ... vape.6379/
http://fuckcombustion.com/threads/the-hi.4693/
http://fuckcombustion.com/threads/aroma ... ckzap.818/
http://fuckcombustion.com/threads/under ... izer.4214/
Only other thing i can say is do your research on a few different vapes before buying and find what fits you, because if it does become a hobby for you and you didn't make the right choice then soon enough you'll be building a collection of vapes and upgrading all the time, rather than finding the one for you first time round and upgrading as little as possible.
If any of the above doesn't take your fancy because your looking for something small / something portable then my advice would be to go for the arizer solo .. not only is this portable and small but it produces clouds just as good as a log vape, an extreme Q or a Da buddah
Hope this helps.
