So I am definitely going to Haarlem, Birdy's specifically, to try their jelly hash.
Everyone and their momma has been raving about it. The last comment I read about it
stu76 called it "divine". I did buy a half gram of the Royal Jelly from Barney's last trip, but
25 a half gram is pretty friggin steep.
Anyways I guess I could smoke it out of a bong at Amnesia but other than that I really don't know
how to smoke hash in anything other than a joint.
So do you think it would be wise to put this expensive hash in a joint?
Jelly hash in a joint?
- redeyezman
Re: Jelly hash in a joint?
The Hash Under Glass method is one quick/cheap/dirty way to sample some hashes. The train was out of service while I was there, so didn't manage to go. Anyone tell me if Jelly is a nice hard hash that would work well with this? Kinda partial to it...
First time was afghan pressed, and that seemed to work quite well under glass
Shells sink. Dreams float.
get 3 bags for 25, 5 euro discount, nice in a joint but much better in a bong (much better aftertaste and high). rip a bit off, put in bong, light it up and toke. its easy to roll in thin sausages for joints.. for me its worth a trip to haarlem for jelly..
Probably should have mentioned in the post that I'm not really into the under glass method
as I'm not gonna be at home and to get those things seem cumbersome redeyez.
I used to do the "thin sausage" method stu, but was told that it's a waste of hash.
So I think I will bong it up.
- puffpuffgive
if it's anything like the jelly hash at birdy haarlem it'll melt into the tobacco/weed as the cherry burns down.. perfect in a joint. a bong is a bit less wasteful but a joint is perhaps a more leisurely way to smoke- i prefer it. i like to mix with plenty of tobacco & weed and make thin sausages with the stuff from birdy. it's a bit challenging due to the semi-liquid texture
ik hou van amsterdam
- redeyezman
Appropriately named Jelly then I suppose... out of bong seems to be the universal answer for best way to smoke. Don't listen to me! I'm stoned!puffpuffgive wrote: it's a bit challenging due to the semi-liquid texture
Yeah ppg I do prefer a joint but stu says they give 3 bags for 25 so maybe I'll will just
have to bear down and try both joint and bong methods
- cantona7
just break it into small little pieces and distribute it among the weed in the joint.
instagram @shooter_mcdabbin
randomsham
Semi-Liquid?!?! I have to check this out, it doesn't sound real
Like the Moon the the Blue Heavens
ʇɥƃıl Çɥʇ ʇno ʇnd ÇÊŒÉÉ¥ ı
