First trip ... Need best advice for first timer
The place for new members to say hello.
sensi315
Re: First trip ... Need best advice for first timer
Post by sensi315 »
I would recommend some light indica at the start instead of sativa which can be a liitle hyper after not smoking for long time at all. But on the other side if you plan on drinking also some alcohol I would suggest sativa like good nepal atleast it will pump you up and not put you into sleep.. take it easy :wink:
Curious_Old_Gal
Post by Curious_Old_Gal »
sensi315 wrote:I would recommend some light indica at the start instead of sativa which can be a liitle hyper after not smoking for long time at all. But on the other side if you plan on drinking also some alcohol I would suggest sativa like good nepal atleast it will pump you up and not put you into sleep.. take it easy :wink:
Thanks sensi315! I will definitely take it easy!
__________________
Live like there is no Tomorrow & Dance like nobody's Watching
