MFLB?
Bad de Grasse
MFLB?
Post by Bad de Grasse »
MFLB?
1. Can you use any AA batts, like Duracells with the cover peeled off ? Or do 2900mAh rechargables hold a stronger charge?
2. Is it better to always fill the trench or doesn’t matter how much is in there?
3. Wanna bring my box (and get it home) Where can I get Isopropyl alcohol in Dam?
Not sure about the ‘more economical ‘ claim which exists about vaping. I seem to be getting through my stash at an equal, if not quicker rate, than when I smoked pipes. Could just be enthusiasm :) . Lungs still feel like they been smoking though. Even though carcinogens are minimised, there’s obviously other irritants in the vapour. Be interesting to read some science about that.
Countdown to Fri
Colina
Re: MFLB?
Post by Colina »
Bad de Grasse wrote:MFLB?
1. Battery is 1,5V, a rechargable is 1,2V! don't know, but a battery could be too much power and destroy or at least overheat the MF. Then it's not vapeing but smoking a wooden pipe ;-)
2. Don't fill to the top, shake and reheat.
3. Plan B is the Roor cleaner, must be ISO based. Don't know if ISO is available in Amsterdam.
HOLLAND
hasj
Re: MFLB?
Post by hasj »
The batteries need to be NiMH at least, but really ought to be LSD NiMH like Sanyo Eneloops. It is all about battery chemistry and how big a draw from them can be obtained. LSD NiMH may have a smaller capacity than NiMH but will out perform them in high power draining devices. I wouldn't even attempt to bother using alkalines.
# on #! on #
Bob2
Re: MFLB?
Post by Bob2 »
save it for when you get home, plenty of coffeeshops have vaporizers..
Bad de Grasse
Re: MFLB?
OK Cheers for the battery info. Shame to leave it at home. Is there a strong chance I'll get it taken off me at the airport ?
