plastic wrap or vacuum bags
Re: plastic wrap or vacuum bags
Lol you should bring that stuff with you
The best is of course a vacuum Sealer.In the times where i bought bigger amounts,up to 750 Gramms,i always used vacuum Sealers.You push the Bag under it,then it drags away all the Air to make a vacuum and then it make a hot-molten Seal to the Bag.The Weed shrinks to little Volume but its not realy pressed.When you open the Bag it makes "wuuush" and all have its normal size again
Back then i had a secret i often used.You can buy liquid latex which is solved in Ammonia,you take a Brush and make a thick coating over the Bag.Then you let i dry and your bag is coated and sealed in latex and smeels like nothing
.When you arrived you can easily remove it.
You can buy such stuff in Shop for Modell Railroads and Scale Modell Building.Its normal used to make copies of pieces with Artificial Resin.But be sure you let it dry complete,im sure Drugsniffer Dogs are intrested in smell of Ammonia cause its also used in Crack-Cocaine.
Oh and its a realy realy good Idea to use a Decoy.
As i brought bigger Amounts from Netherlands to Germany we alwas drove with 2 Cars.1 Car had lot of crazy People with hardcore-Techno very loud,a Jamaican Flag with Cannbis on it in the Backwindow... their Job was it too look suspicous.And the other car,looking normal,with no musik and no crazy people inside followed 2-3 Cars behind with the Weed on board
It always worked,always the Bordercops took out the Suspicious cars and then was busy and the car with the weed could drive trough
There is. You can get everything you need from the old Interpolm shop - now the Dampkring head shopgluegun wrote:Goin to buy a roll of vacum sealer bags and bringit with me you can use and iron and a flat surface to achieve the same thing just thought there might have been a shop that could help out
https://www.coffeeshopdirect.com/InterpolmAms.html
They have heat seal bags, vacuum sealers etc.
http://www.dampkring.nl/head-shop/packing-sealing/
If Frankenstein came face-to-face with the monster Marijuana, he would drop dead of fright.
