Reasons for Weed with Soap Taste
Anyone knows Weed which taste like alkaline (soap like) ??
Which Chemicals cause that ? Is it possible Fertilizer can cause it ??
Please only answer when you 100% Sure that fertilzer or a other Chemical you know causes this alkaline soap taste,specialy when breathing out the Smoke.
- redeyezman
Re: Reasons for Weed with Soap Taste
I think when they mix with stupidity, it taste like soap.
Shells sink. Dreams float.
When they Mix what??
This is realy serious,if i cant find a "good" explaination for the Soap Taste it must be JHW-108 cause it has the JHW-018 smells and light reflecting "stars" in the normal yellow/white Buddust.
And this would mean a coffeshop sold JHW-018 Weed.
http://en.wikipedia.org/wiki/JWH-018
Yeah or it's just soapy as certain strains are. A certain phenotype of white widow for example is really soapy.
I don't say it couldn't be JHW018 either, I wouldn't be surprised if shitty shop sell that shit.
Well it was sold as Amnesia
Where did you buy it?
Amnesia tastes soapy imo, probably more so than anything else.
Well, it was sold in Quiam Eygelshoven,one reasons why i found the Amnesia so Suspicious is that the same shop was more than 1x accused to have sold Brix Weed.
In Germany we have a Hemp-Community Page where you can send reports about bad unclean Weed,normaly thought for Streetdeals.But they recieved so many reports about Brix Weed from Quiam that they made a official Warning on their Homepage.
http://hanfverband.de/streckmittel/meldung_3539.html
http://www.growshop-greenbud.de/indoor- ... n-mit-brix
You can find more Reports in Various Forums..just google for "Quiam Brix"
So the Risk that a shop who already sold Brix also sells Haze-Spray Weed (JHW-018)
But its only the Amnesia,the other Weedstrains are all ok and the Hash is ok too.
The other Point is that the Ash is not clean white,it has alot of black pieces in it which not burned to Ash.I smoke with a 10cm Lighter Flame cause i dont like this rings of unburned Weed in Pipeheads when smoking with little lighter Flame,so i always use this big ones and normal all weed burns to fine white Ash.But the Amnesia Ash has alot of black pieces which not burned correctly in the Ash-remaining.
When i bought Weed as "Haze" from the Streetdealers which was contaminated with JHW-018 it had the exactly same Ash and the same Soap-Taste..It also had the not-normal "light reflecting stars" inside the normal buddust.When you put a normal Bud with alot of buddust next to a lightbulb you can see the white&yellow Buddust,thats normal.But at the JHW-018 Weed inside the normal Buddust aren little points which reflects the light like a Mirror,it shines like a star inside the Buddust.Thats typical for Haze-Spray JHW-108
you find that kind of weed a lot in the border area... in Sittard and Roermond (Skunk Coffeeshops) the Amnesia
and Silver Haze are sprayed, too.
I would say nearly 50% or more of the weed in the border area is not clean (at the moment)...
I never liked the Quiam Shop. The Shop itself is nice but the weed and hash is poor. Only the most expansive hash
(I think Shirra it´s called) was nice.
Have you ever tasted haze its like perfumed soap but in a marijuana way hink you germans are at your lark lol only joking please no offence intended
I had a little bit of the Amnesia and Silver Haze (from Sittard) on my last trip to Amsterdam with me...
I showed it HB from Voyagers and he said yes that looks like it´s sprayed
Ps iv had many types of spray and there methods have got better iv actually seen a weirder method used by gangs from diff countrys in the uk its called fast drying and please i dont have a clue how they do it but my friend opend a klick and it was bone dry he got it home an hour later and it was soaking was gave straight back and a bit of trouble started but still dont have a clue how they done it
Well the guy from Quiam seems to buy 10 tons or so from his Relatives in Moroco and then sell it for years,the Hash seems a bit Old but Zero and Shira are good,Pollen is awfull,Ketama too (very cheap 5 g 15 euro),and i not tried the Afghan yet.
But the Problem with their Hash is also that they cut it with a Knife wich they (i guess ) put in boiled Hoter cause you not see any black remaings at the cut area so i think they heat the knife without a open Flame.After doing this every Hash seems old...its definately bad for Quality doing this.Or they could put the bar close to their body to gently warm it.
They sell the same type of Hash as long as i can remember back,must be 20 Years,always the same types.Sometimes Ketama Special is changed for Pollen,and sometimes they get Afghan instead of Skuff.
Weed they always have 3 Strains,Snowball is there for some Years now,White Whidow always too,and a 3th Strain which can change,atm its the suspicious Amnesia.
I realy should try the other Coffeshop in the Area,when i look on Google Maps it seems to be in a forest Area? But atm i lucky i can go to Coffeshop again as "Tourist" so i not realy complain i just dont like this Spray-Shit.
But 80% not even notice when they smoke Brix,i think the people who notice jhw-108 spray is even less than that
