I grinded the Weed and put it into a 0,2 Glass.Then i added 6x 5ml Syringe of Lecithol over the Weed.You could instantly see that something happens.The Clear Lecithol became green instantly and you could see a bit of brown glance swimming in the green solution (i guess its the resin?).
I used a fork to stirr it,let it set,stir it and so on for about 2 Hours,then the Weed looked leached out and i was sure there is no more "medicine" in it
I then took a Glass Funnel and cut a classical "chemistry" filter from a coffe filter (first round cut,then you bend over 1 part so it forms a "chinese hat" shape to fit into funnel)
It took some time to get it trough the Filter but in the end it worked good.It was also noticeable,that before the Weed contact the Lecithol was clear,thin and unsticky.After it took the Ingredients from the Weed it was green,more thick and oily and it became sticky.You realy can see it took all the good stuff out of the Weed
>Today i made the first test and put 25 drops of my Lecithol into a GLass with Vanilla Milk.
Then i was a bit scared and drunk only 1/3 of the Glass,after 50 Minutes i dont feeled much but i noticed it,so i drunk another 1/3 of the GLass.10 Minutes later i feeled extreme stoned,this stuff definately works.The 2/3 of 25 Drops would be in Weed not even 0,1 Gramms.And i feel so much more stoned than 0,1 Gramms now.
Like i mentioned before in this Forum i often made me a Tea with 0,3 Gramms of Weed,and the 2/3 of 25 Drops = 0,07 Gramms of Weed is at least twice as strong !
So for me its absolutely prooven that Lecithol increases the Effect compared to smoking at least 5 times ! (this would fit their claim that you get 5 to 9 times more thc into your brain than with smoking)
This Stuff is realy cool,the Bottle looks not like a Drug at all.Its just written Lecithol and a Green Leave (neutral leave no Cannabis) and then the Ingrediens listed : Alcohol 78%,Polysorbat80,Sesame Oil,Lecithin,Peppermint Oil
You could tell anyone who ask just thats some Homeopathic Medicine or something like that.
It would be perfect to bring into places wheres drugs are absolutely not allowed or when youre at Work or so
You also get sleepy from it,i guess with a pure Indica even more than with K2 ,K2 is a very balanced Strain for me.
End Result is good,you get a big increase in Effect for just a few Bucks (7,50 for 50ml Bottle,10ml is needed per Gramm of Weed)
Producer say its good to use for at least 4 Months after opening
The Taste is intresting too,its realy like concentrated Cannabis taste with a minty note and the sharp Alcoholic taste.The Alcohol can be boiled away by heating the Lecithol Solution at 78 Celsius,then the Alc. vaporates (Alc boils at 78 Water at 100 Celsius)
The stuff realy works
Edit: I forgot to Mention that i had already smoked 1 Gramm of Hija and half Gramm of K2 today but i dont felt stoned much as i took the Drops.
Since i noticed the effect a hour after taking,i realy dont want to smoke a Bong or anything else now,this stuff can sure help to reduce the Money you spent on Weed !!I think my thc receptors are complete occupied now lol
