Herbal highs
- jim and sonja
Herbal highs
Just been on a few websites looking at herbal highs, has anyone tried any of these, if so would you recommend any.
I smoke, therefore i am
/\/\/\/\ yep!
learned the hard way years ago. Bought a bunch of different herbal things and got nothing more than a headache and/or nausea from all of them.
Salvia on the otherhand.....i've not had the crazy 30min intense 'trip' but i definitely feel something from it the handful of times i've tried it. I need to get my hand on some of the 20X extract and give that a go.
- Kaiser Saucy
depends what your looking for.
(stimulant).....ephedra if you can find it, sida cordofolia if you cant
(relaxant)....kanna is excellent stuff on its own, nice effects from smoking as little as 200mg, and as a bonus it potentiates weed. A little kanna in a joint & you will really notice a difference in effects. It also has a reverse tolerance, the more you use it the less you need.
kava kava is made into a brew...very relaxing, great stress buster.
There is a mix called spice which is raved about by a lot of people as being a great substitute for weed....but its pricey £12.50 for an eigth. Also it seems to work for most people but not all, i didnt get much from it.
(Psychedelic)
You can legally but San pedro, peruvian torch, & peyote cactus in a lot of country's. These cacti contain Mescaline....which is one of my favourite substances.
Morning glory seeds...contain lsa, some people get nausea from these but smoking some herb works wonders with shifting it. I very rarely get nausea & ive had some great trips on these. You can also use hawaaian baby woodrose but these carry FAR more nausea & body load.
fly agaric mushrooms....not at all like psilocybins but they are a trip in their own right. deep relaxation, colour & sound enhancement, mood elevation.
There are more i could mention, but the above gives you some idea of the potential out there. check out 'deva ethnobotanicals' they carry all the stuff mentioned except ephedra & spice.
hope that helps
(Psychedelic)
hope that helps
Or you could try nutmeg from your local grocery store.
I personally would recommend not to though.
http://www.erowid.org/psychoactives/faq ... tml#nutmeg
My thoughts are free.
- jim and sonja
- Punkindrublic
Bringin up a bit of an old topic.. but i had 15x salvia the other night.
Tried a small amount first time as i was a bit unsure what to expect.
felt a bit heavy headed and things looked a bit blurry, so decided to go for a bigger hit.
It works, thats all i will say.. Tripped pretty hard! For about 10 minutes my best trip lasted (did it a few times) Had some visuals, and really changes your way of thinking. For a while i was convinced i was on a boat.
Reckon i might have to try the 40x as i thought salvia was great, little expensive.. but worth a try!!
Stay Free
- pan4gold49
Redeye wrote:You two crack me up!!!For a while i was convinced i was on a boat.
May I ask how you smoked it, Ive tried it before with no effects...I heard you gotta torch it up in a bong or similar items...hoter the better?
just put it into a pipe and toked it, i found it to burn the tongue and throat quite a bit. then just gotta hold it in for a while ( they said for as close to 15 seconds as you can)
apparently a bong is good but pipes best cos it needs to be really hot to work?? im not really sure
- Kaiser Saucy
The salvia needs as much heat as possible so a torch lighter is best, bongs and pipes are the best way to smoke salvia, joints just dont get hot enough to release enough of the active. Deep breath hold it in for 20+ seconds.
Salvia has a reverse tolerance so you can need to smoke a potent extract to get there. Once you have though, you actually need less salvia to get equal or greater effects.
Yeah bong and Holding it down for the longest time possible.
Always love that exhale when your last words are:-
"That's done fuck all..............." Then you come round somewhere else in the house wondering where all the aztec conveyer belts have gone.
I was once found on the floor in the corner of the kitchen muttering about it being "Too late, it's just to late!"
When the going gets weird, the weird get going!
