Hello,
I'll go with a friend to the netherlands from 1st August - 11th August and I want to try the Gunpowder of the Bluebird ... but i dont know how to smoke this stuff ... can i put it like weed or hash in Joints or mixed with Weed in Joints or what ?
Gunpowder is from Stix coffeeshop, pretty sure nowhere else sells it - closest you will get is the grey mist crystals from Grey Area.
As for smoking them, mixing a small amount of crystals with pure tobacco or another weed/hash mix would be fine - I wouldn't put too much in as you really don't need it and it would be a shame to waste any. Not being a joint smoker myself I prefer to top off a bowl of weed in a pipe with a sprinkling of crystals - or better yet on their own in a glass pipe to get a pure kif buzz!!
hehe ... i meant stix ... i want to try the blue cheese of Bluebird
I'll buy the gunpowder because its cheapier than the grey mist crystals ... ... what do you mean with small amount ... 0.2g or what ?
I'm not that super duper smoker
Judging a smoke per weight of crystals may be hard as 1g looks suprisingly a big amount. I was taking a teaspoon and using the thin handle end to just take out a tipful of crystals from the bag - the first time I smoked them I had filled up a pipe bowl full of crystals and began to smoke them (this was bad as the pipe quickly clogged up and a lot of wastage was thrown away - but I soon managed to judge what a lungful would take)
A rough estimate I would say that you could get 15-20 good (pure crystal) pipe hits from 1g, so that would be something like 0.075g - 0.05g per pipe I guess?!?
I make a pure joint of something strong like MK Ultra, Poison or say Mothers Finest then sprinkle about half a gram in for that little extra kick!! - Warning this stuff rocks!!!
Shorty wrote:Where abouts is Stix? Wouldnt mind getting some crystals when i go next week.
They have 2 shops and both are really nice, theres one at Utrechtsestraat 21 and the other (this being my favourite for the view) is located at Korte Koningsstraat 2.
I was kindly given a gram of Grey Mist Crystals by Neuro who I hooked up with during my recent visit. He also included about the same amount (maybe more) of Buddha's Sister weed.
I had tried todo a pure joint of the weed but I just couldn't get the thing to light up at all so I emptied out the weed and mixed in some tobacco and then decided to mix in some crystals as I was going to bed and wanted a good sleep.
The joint really did the trick but when I awoke in the morning, I noticed that there were a few hot rock holes in the bed sheet and this was obviously caused by the crystals. I should have been more careful not to smoke so healthy a joint in my bed.
The moral of the story is that if you're gonna smoke crystals then use a pipe or other non joint smoking method.
Doog wrote:I was kindly given a gram of Grey Mist Crystals by Neuro who I hooked up with during my recent visit. He also included about the same amount (maybe more) of Buddha's Sister weed.
I near enough always buy some crystals of some description and only smoke them in a pure weed joint and have never come across any hot rock holes, its not soap bar your dealing with mate must of been something you did or didn't do!!
I got a good sized pile after using Space case onsome bud I put in freezer for awhile. Did 2 Vapo bags, putting the crystals between 2 layers of weed and got the highest I've been since being in Amsterdam. Very glad I purchased case,grind over large piece of glass and WOW...
Boner wrote:I near enough always buy some crystals of some description and only smoke them in a pure weed joint and have never come across any hot rock holes, its not soap bar your dealing with mate must of been something you did or didn't do!!
I suppose some of the crystals must have sank to the bottom of the joint and fused together (this has been known to happen). You have to shut the rolling machine in order to roll the joint do you can't really see where everything's going (unlike hand rolling where you have a birds eye view of everything during the rolling process.)
There were no problems with any of the other joints I "went to bed with". Just the one that had the crystals included.
