I've been saving my vaped weed for a while and have over an ounce of it sat in a jar.i was wondering if any of yous have experience of using vaped bud in brownies etc
Does anyone have any good recipes to make cannabutter?
Will they freeze ok and how long do they generally keep for in freezer?
Thanks
Making edibles with vaped weed
Re: Making edibles with vaped weed
Yup, I do this all the time. The ABV still has a lot of cannabanoids inside, can give surprisingly strong results!
The basic technique I use:
- Dump your ABV into a clean cooking pot
- Pour in enough warmed coconut oil until the ABV is submerged by a centimeter or so
- Add a few spoons of soy lecithin powder (this dramatically improves absorption, meaning you'll get more effects from the same amount)
- Blend everything with a hand-blender until the ABV is fine powder, this increases surface area for better absorption
- Cook on low heat for at least few hours (gentle simmer, not boiling!), stirring often. Some people cook for 8+ hours, but IMO this uses too much gas to be worthwhile. Its not worth spending an extra $20 on gas just to get that last 5% of cannabanoids out.
- Allow to cool
- Put into the freezer overnight
- Allow to defrost, then reheat the mixture for 30 mins or so, don't forget to stir
- Strain out plant material while oil is warm
- Allow to cool and solidify, then keep the finished "green oil" in the fridge
If you have a lot of time on your hands, or you're just a perfectionist, there are many ways to improve this basic technique. But I've found this gives me the results I want, without being a scientist about it
Its also possible to do a second cook with the same plant material. The oil won't be anywhere near as strong as the first batch, but it'll still have some effects. If you have plenty of spare weed lying around, don't bother with the second cook of course
- Allow to cool
- treetop
Thanks Bleak. Also have a lot of ABV here too. Going to try that. Might use the strained product in a soup/stew though.
How much did you produce?
Thanks bleak.sorry to sound dumb but is there a specific guideline of how much vaped weed to oil.then once in its oil form how much oil per batch of brownies or cake
Thanks again
Thanks again
Are you aware you dont have to prepare ABV at all?
I understand why some would want too cook it into something else, but it's just as effective when eaten straight.
The highest i've ever got are the times i eat ABV. I usually just chuck it in a yoghurt. Last time i put it under my tongue and then washed it down with booze...
