shatter
shatter
Went to nephew 21 birthday party last night.A couple young guys, just got back from Calarodo. The shatter hash they had was girl guide cookie ,grape ape.I was interested ,tab butter lots never tried the shatter.Being in one of his buddy,s parents house ,I asked where,s your rig.They led me out to garage.Where they took out tin foil , gave me a straw.I went hang on,memory flash back chasing dragon .Sure shit that,s how they smoke it on the run.Never seen that before , but I,m old. But I,m Happy
Roll on 420
Re: shatter
Method A: Using aluminum foil, candle and a tube
An easy way to vaporize THC oil is by placing a drop on a piece of aluminum foil, heating this over a candle, and inhaling the vaporized oil through a tube such as a straw. A tube that works especially well is from a clear plastic Bic pen. The tube is an improvement over the nose in getting over the rising air full of the vapor, which rapidly condenses into tiny droplets of oil. The tube also helps to control the temperature of the vaporized oil before it enters your lungs, by catching it an inch or so above the foil after it has cooled some. Hold your tongue near the mouth end of the tube, as a way to further cool the vaporized oil. Your tongue should be protected against the heat by wetting it often with saliva.
http://www.hightimes.com/read/high-time ... nd-here-it
Re: shatter
it will work,but as said,your look like your doing heroin,not a amsterdam cs look,get a e cig battery and a wax attachment{8e}and you got the best rig for the price
