skuff
Re: skuff
This form of cannabis is often refered to as kif. As 711 said it is sold at Gray Area and kif is also sold at the 2 locations of coffeeshop Stix; under the name of Gunpowder. Peace.
mdhfc wrote:the nice powdery green stuff that crumbles like an oxo cube... where can you get it ?
i remember having some last june but was too wasted to remember where i got it and havent seen it since...
Cannabis is The Tree of Life
I agree Twitch.
I did it recently with an ounce of Super Skunk I got.
I used my grinder as I smoked it, and afterwards, I had a nice collection of powder which I smoked by sprinkling it onto tobacco in a joint.
Absolutely knockout stuff it was, and suprisingly, it tasted and smoked quite differently to the super skunk.
In Australia a lot of people use electric Herb'n'Spice grinders AKA a coffee grinder to chop up their weed, and after a while of using one of these things, you get a buildup of kif on the lid and under the blades..
models with dome shaped lids rather than the type shown here work better (produce more dust).
I have a small space case grinder, the one with the crystal catcher. Only problem is, I had to remove the gauze. It had so much herb go through it, no more crystals would go through. I tried everything, well mainly boiling water, to free the trapped crystals, but to no avail. It was a communal grinder for about 3 years, and alot of smoking was done there.
I poked the gauze out to have more room for herb, but found it too annoying, so I took out that section completley. Now the herb goes from the top, through the holes and to where the crystals used to be. It does mean that gram or two can be done at a time, but if I need more I have the giganturnorumous one
Lol, a stoned ramble
- islandgurl
