https://youtu.be/MdfBCuJj7rQOneHighMofo wrote:I looked at that one - feels real nice in the hand for sure.dconstrukt wrote:btw… this looks pretty awesome
https://www.thefirefly.com
not cheap but can do concentrates too.
The Firefly is pretty nice. I like the '1 button instant heating' a la Magic Flight.
One thing that put me off a little: the load ALWAYS needs mixing to get an even cook. If you don't mix, the load is still green in the center. Personally I find this too much bother & mess, as I usually need 3-4 bowls to be satisfied. Getting high shouldn't be such a lot of work
Also, the battery life of the Firefly is surprisingly short compared to others. Because of short battery life, along with the chunky size & weight of the unit, I think the Firefly is best as a "home portable". Something you can carry around the house without need for cables.
Keep in mind if you're using dry flowers, these coil-based devices are well known to combust your material, which technically disqualifies them from being called vaporizers. They are electronic smoking devices, which is a different category. What they produce is a mix of vapor and smoke. Nothing inherently wrong with that, but I think its important to know the difference, especially for those people with health concerns about smoking. Mind you, I'm aware that some users have modified their units with ceramic spacers etc. which make them closer to true vaporizers.BackInDam wrote:GPro and MicroG Pens in Amsterdam for really cheap, like 20-30 € each.
They still work very well
I'll be testing the Crafty & Mighty soon, quite curious about them!
