How Are You Smoking Your Hash?
SpiritWeed
Post by SpiritWeed »
Question is in the title.
I gave up tobacco at the tail end of 2013 and have got increasingly into my hash (BHO).
Now I know BHO is illegal in Dam but you do often see QWISO which is dab-able (I have a cheap bong/rig combo I'm taking out there).
But what about other hash? Like Bubble / Ice or even Nepalese, Maroc etc..
Is the only other way to smoke it when put ontop of some flowers in a bong bowl (not a problem if so)
I'm just looking at more options, doing hot knives in a CS isn't the easiest of things I'd imagine!
kingbee
Post by kingbee »
Yossarian22
Re: How Are You Smoking Your Hash?
Post by Yossarian22 »
You have a couple of options. You can mix it in with weed in a joint but the problem with this is that it seems like it wastes a lot of the hash- every time I smoke a joint like this, it seems like the hash burns fastest right after I've finished inhaling the (mostly weed) smoke(ie, on the inhale, it's mostly weed but the cherry from the inhale causes the hash to burn after I've inhaled.) There is a helpful little invention called Health stone(basically a porous limestone-like substance that you put in the bowl. If you've ever used a Vaporgenie, this is a similar idea.) However, the simplest way is to just smoke some weed from a pipe/bong then not empty out the ashes. Just place the hash on top of the ashes and smoke. That way, the melting hash coats the ash instead of dripping down into the stem. Also, some coffeeshops(like Bluebird) have a hash bowl to use with a Volcano vaporizer.
Adamster
Post by Adamster »
I like my bottle tokes but need a smoke for that :|
