Guys,
I appreciate any input on the following points. Any recommendations where to get these online in europe appreciated. I actually found a place and the below questions I sent to them, but also posting these questions here to get more opinions. The place I enquired is greenhouseseeds ( hopefully this will not be seen as advert here, and I can remove the name if needed )
In all cases I like energetic/creativity kinds.
1. Non-genetically modified seeds. Do you have non-modified ones and if you do please recommend those that are "least" modified as I prefer natural ones. ( please recommend plant names so i know what to look for on the websites )
2. Indoor Grow. Can you please recommend me a kind for indoor growing. ( I understand these can be feminized/autoflower which is ok ). I need it: To be of the small to average size ( for balcony growing ), has the fast grow characteristic ( 10 weeks or so ). It should be an energetic/creativity kind.
3. I need few seeds ( 3 - 5 ) to plant in a forest outdoors. These should grow over the summer, with minimum required visits. If you have such please advice.
4. Looks like the so called Ferminized/Autoflowering means that they are geneticall modified. True / False ?
4.1 With regular seeds that are NOT Ferminized/Autoflowering , how many days I am looking at before harvest, for both indoor and outdoor(outdoor with little supervision over the growing process ).
5. With these "regular seeds"/non-modified how many I need to order, because I read that it is not known which ones are males and which females , and I need both from what I understand ?
Thank you and looking forward to hear from you.
Growing some plants for first time, please advise ... !
- RvanSteensel
Re: Growing some plants for first time, please advise ... !
i'd go for both autoflowering and feminized .
i dont like monsanto and stuff but i'd still go for these seeds.
they dont use gene cannons so its not so bad
id go for auto silver haze
with GOOD quality normal seeds about 60/80% will be female.
Ten weeks on balcony ,better go with auto flower.If you can start under light for a month before you put outside you could use fem. seeds.Good luck.
gettingrimey
The forced feminisation of seeds is a forced genetic mutation.
I be chillin on the beach in the South of Venice
Or merking the President live on Channel 7
JimmyChoons
JimmyChoons
JimmyChoons wrote:kingbee wrote:Re: point 1;
There are no "genetically-modified" seeds; that's a common misconception amongst IGNORANT PEOPLE.
Avoid Greenhouse. Stick to indica's or hybrids if you want to keep small plants or learn to train them. Haven't messed with autos but fems can be OK. With regs you'll have to sex them. You don't need both m and f. Cull the males once they show pre-flowers unless your breeding.
In all fairness thou mate based on your questions above I'd do some serious reading first before even cracking a bean.
Best of luck!
Jc
