Vapes
matty223
Vapes
Post by matty223 »
im looking to buy a new vap,, i like this one anyone V2 Pro Series 7
have any suggestions ?
peace matty
MinnBobber
Re: Vapes
Post by MinnBobber »
Do you intend to just vape flowers or do you need ability to do flowers and liquids??
IMO, those pen style or just bigger than pen style like this are not the greatest.
For similar $$ or just alittle more, an Arizer Air, or Haze V with the world's only 2 chambers are much better.
Need more info to help.
do you have a vaporizer now? what?
Mostly intend to vape at home? on the go? both?? need to be small/stealth sized or is slightly bigger ok?
I assist new med mj patients here in MN get into vaping. Many are low income so I help them get a high quality vape for minimum $$ that fits their vaping needs.
I'll try to post pic of Haze dual chamber:
MinnBobber
matty223
Re: Vapes
Post by matty223 »
ive had a few vapes,, im justt looking for suggestions ,,
oh i stick to flower
Peace matty TSA
Black-King
Re: Vapes
Post by Black-King »
stumbled across this article when I was reading something else, dunno if it helps but I am linking it anyway, http://www.thecannabist.co/2014/12/22/b ... ers/25747/
RASTAFARI RIGHTEOUS KINGDOM http://rastafari-christ.webs.com/
matty223
Re: Vapes
Post by matty223 »
well i think i have narrowed it down to 2 the V@ or the Pax
Black-King
Re: Vapes
Go for the V2 Pro Series 7
dconstrukt
Re: Vapes
Post by dconstrukt »
the mighty.
the only thing that remotely comes not even close is the airizer solo.
but the mighty gets much better clouds.
DedsOne
Re: Vapes
Post by DedsOne »
dconstrukt wrote:the mighty.
+1 Mighty all day.
OneHighMofo
Re: Vapes
Post by OneHighMofo »
+2 Mighty for King
This thread is quite informative :)
viewtopic.php?f=7&t=30719&hilit=portable
dconstrukt
Re: Vapes
curious what you guys have your mighty set to....
i tried the lower temp's like 360 F... but i barely see any clouds.
i'm pretty stable at 385F and get mega clouds.... but I'm sure it depends on the strain and how good it is.
OneHighMofo
Re: Vapes
I'm usually a bit lower than that - about 375.
I prefer to prolong the taste rather than blow thick clouds. I'll only turn it up as high as you to vape oil/hash
DedsOne
Re: Vapes
Post by DedsOne »
I vape at 370F most times and that works fine too me and as OHM sayd i only vape at higher if im smoking hash or other concentrates.
twinkles
Re: Vapes
Post by twinkles »
I am going to go "vape" on my next trip. I have traditionally ground a gram of hash into a gram of flowers so that my smoke was potent, but the joint burned well. Will this work with a vape, or is it nutso for some reason?
And just as info, my plan is to buy a mighty for the trip.
OneHighMofo
Re: Vapes
twinkles wrote:I am going to go "vape" on my next trip. I have traditionally ground a gram of hash into a gram of flowers so that my smoke was potent, but the joint burned well. Will this work with a vape, or is it nutso for some reason?
Short answer - the efficacy of vaping hash in the mighty depends on two factors:
1. The quality of the hash (with regard to amount of plant material / other contaminants)
2. The heat you have the unit set to.
Vaping low grade hash will definitely require hotter settings (>200°c) than you want to vape flowers at (and retain a tasty, smooth hit)
Vaping high grade hash or oil - still requires hotter temperatures (>190°c) but will still deliver a palatable flower hit.
The Mighty comes with a mesh disc specifically for vaping concentrates with. So although you have a lovely idea - logistically it's fraught with the danger of over-vaped flowers, or wasted under-vaped hash. Personally My advice would be to use the concentrate disc with Hash or Oil of any grade and then turn the vape down to 180 / 185 °c and re-pack a nice bowl of flowers. Or vice-versa :)
MinnBobber
Re: Vapes
Mighty will do an admirable job of that. A slightly preferred method by many is a "hash sandwich" with some bud on the bottom, tiny pieces of hash as the "meat" , and another layer of bud on top. That keeps any kind of hash dribbles from going down into the Mighty. Hash ground up with herb puts some hash pieces right on the bottom screen.
Mighty does a very good job of cooling, with its "cooling unit" (CU) top. Hash sandwich at 210 C (max Mighty temp) will work just fine. I don't have hash here BUT "temp step" up with the Mighty (350F, 370F, 390F, 410F-max temp) and it's fine. In fact, I then move the 410 F herb over to another vape and temp step at 425 and 445 F to finish/get all the goodies out.
Also, at a coffeeshop with bongs/ water pieces you can easily use the Mighty with water----if you can find a water piece with good clean water/ not all full of combusted herb gunk. I had a guy make an adapter so 2 seconds to convert Mighty to use with bubbler.
[urlImage][/url]
