Cannabis Oil
X
Cannabis Oil
Post by X »
I met this guy, here in BE... the guy was smoking a cig and was getting stone.....
he showed me how he used a toothpik that he dipped in cannabis oil and trailed along the cig.. it works quite well as I tried it myself..
know if thats foundable anywhere around the Netherlands?
Scott.
mazdog
Post by mazdog »
you can in fact make "honey oil" or "iso" oil quite easily. both involve extracting the oil from the plant material using chemicals, then purge out ALL the chemicals leaving you just the pure extremely potent oil.
http://www.overgrow.com/edge/showthread.php?t=556897 The method in this thread works perfectly! eye know for a fact!! Just be sure to take EVERY safety precaution necessary.
there are other methods descrided on that forum as well.
as far as any shops selling oil, i have never heard of it. the closest you might find is jelly hash, which in some case is simply "honey oil"/BHO miced with kief or tirchome crystals.
miguel
Post by miguel »
take a jar with cover to watertight closing.
put in the grass, or the smoke, (min. 5g.)in the jar.
cover with pure alcool (95-98°) leaving to macerate for 2-3 days.
put the liquid filtered (without leaves, etc) in one small pot.
put bubble some water and put over the water the small pot whit your solution.
As soon as the water bubbles extinguish the fire. (the alcool evaporate at 80-90° but if it goes over 110-120° it make fire... caution)
Repeat the operation until will remain only one poultice whitout liquid.
ignite the lighter and make one blaze. Therefore it will go out also the vapor of the alcool.
If the alcool begins to burn extinguish endured and replace the pot over the warm water.
In the pot there is the oil.... put it in a plastic little box and put in the freezer.
You can't put all the oil of the pot in the box.... open some cigaretter bring in the pot... put over the fire and stir.... whit this mixed make some chiloom
miguel
Post by miguel »
miguel
Post by miguel »
miguel
Post by miguel »
sorry but the forume give me an error.... that It don't send my message.... but It send it... and in 3 copies......
mazdog
Post by mazdog »
Miguel, that sounds about right. But you will get significantly better quality oil is you only leave the acohol in contact with the herb for 2 minutes or less. In two minutes the alcohol will dissolve the majority of the THC, any longer time and the alcohol will start to dissolve nasty plant sugars and cholorphyll.
also i'd reccomend purging the alcohol outdoors, you really don't want a house full of highly flammable alcohol vapor.
