If you're reading on a phone you might see these behind the menu options at the top of the page.
I usually view the site on a big screen but I was looking on my phone the other day and thought the green (radial gradient) buttons were rubbish! Then I had the idea of using joints so I knocked this up.
If your phone is still showing the old buttons you may need to clear the cache in your history settings.
On some devices you may never see the lit joint. If you're using a mouse it should appear when you roll over it. On a touch screen it will appear when you tap on it until the new page has loaded. On Apples it will probably not appear but everything else should work.
If you're into graphics and can help me improve this, please get in touch.
