I've only started smoking recently (within the last month) but I still find that when smoking just weed from a joint:
- One full joint is way too much THC for one sitting (I'm a lightweight)
I'm not able to handle the smoke without coughing and feeling like my throat is on fire
- A bag lasts for about 10-12 Joints (using about equal amount of weed and mix)
By itself it has almost no taste / flavour and is very mild on the throat
It has a much steadier burn than weed (Its great in pipes because the weed will go out but the mix stays lit so the next time you take a pull you don't need to relight it)
Basically, I have no idea what's in it, it smells a bit like tea but its green in colour.
Do any of you use a mix when you're smoking (or used you)?
If so what do you use as a mix?
