where can i buy a protopipe
salty seadog
Post by salty seadog »
I am looking at buying an original protopipe but they are nearly £30 in the uk. Does anyone know of anywhere that definitely sells them at a reasonable price in the dam, as i will be there next week...ish...
cheers...ssd
Choo Choo.....
Hoop66
Post by Hoop66 »
So did you get one?
I'm also looking to buy one, but I was wondering if anyone had anything to say, good or bad, on whether I should or not.
I've read some things saying that the brass alloy that they use has lead in it and that this is bad for you as you don't want lead vapour in your lungs, obviously. I'm a bit skeptical, as surely the temperatures needed to vapourise lead are higher than those you get from a lighter?
I've also read that they get too hot to hold while you're smoking them. I've used one in the past, but don't remember that being a problem. That might say more about my state of mind while I was using them, mind...
Any info gratefully received. Cheers.
McBong
Post by McBong »
You can get them here Old Indian Headshop 2 diff versions ranging from 34.5e to 47.5e, the later being the original one. Click Special pipes & Parts.
Peace
McBong
Guy on the Couch
Post by Guy on the Couch »
http://www.everyonedoesit.com/online_he ... astCatID=1
Cheers!
Edit: Sorry i'm high and tl;dr the above so i only read "Where can i find a protopipe?"
Not sure if it's worth 30 quid though...
Sincerely,
The Guy on the Couch
