(did see them about, but in my stoned fog can only 100% confirm them in Dolphins and Tertalia, there are others though, keep a look out)
VERDAMPFER VAPORIZERS- THE BEST THING SINCE FIRE
HP Dubcraft
Has anyone tried one of these yet??? They have about six or seven of them in Dolphins and a couple in Tertulia..... By far the best vaporizers ever! knocks the socks off the Volcano. Looks like normal glass bong with big test-tube heating plug thing that goes where the fire would go. Absolutely phenomenal, the clean taste of a vaporizer and the stern hit of a bong, can't go wrong, try as soon as you can.
HP Dubcraft
They're pretty easy once you get the hang of it. At Dolphins you need to ask the staff for a deposit (10 euros, which you get back) they will give you a glass bowl, like that from a bong... Put bowl in usual place with smokables inside.... Then, you plug the test-tube heating element thing onto the top of the bowl (where you would usually hold your lighter or flame) The element produces a constant heat, so once plugged in all you need to do is inhale.
Its like smoking a bong with another person holding a constant flame up to it for you. It doesn't need turning on and the force of the inhale brings the heat up, so you won't burn all your smoke away whilst getting your breath back.
It can be a little overwhelming as it is very economical and a good-sized joints worth of smoke in the bowl lasted me about seven minutes, by the end of which I was dripping onto the floor, so a good one to share.
Also fun to watch, one of my favorite pastimes was lying back in Dolphins watching people use these contraptions and seeing the reactions. One of my favorites was seeing people lying head to the table face in hands and slowly shaking their heads left and right, making low moaning noises before falling on the floor.
A most drunken like high, check it out.
HP Dubcraft
- Bhang Buddie
Did the one in Willie's last year, just before I left to come back, and was still off my face around 15 hours later after I got back -
Verdamper rules
- I did put everything I had left into it tho', which was in the region of a dozen bags of grass and hash left overs
all mixed up and ground and stuffed in
Bom Shiva
Sidthecrow
HP Dubcraft
Because nothing is actually burning on fire, its not as thick or harsh on the lungs (as there is no burnt carbon) this means you can taste the marajuana without all the other impuritys and smoke by-products. You get a very distinct flavour of the particular herb and its far and away the best way for connessior-like taste comparisons between different types of weed.Sidthecrow wrote:Out of interest as a vaporiser virgin what is the smoke/air (???) tatse like is it like sucking in warm air that has a hint of herb, I have a pre-conception that it is going to be like sucking on a glade plugin air freshner.
Basically, you know that lucious first-contact smell you get when you walk into a coffeeshop????
Thats what vaporisers taste like.
Sidthecrow
Have owned a Volcano for over three years, and have smoked the VerDamper at Nes a few times.
VD very nice, but since I have cats am not a big fan of glass on glass pipes.
Volcano very solidly built.
Here is some info re vaporizing for those of you who haven't seen this before.
http://www.canorml.org/healthfacts/jcan ... rvapor.pdf
Old School and Proud of It.
