Need some advice please would like to visit good coffee shops in and around Amsterdam.
My problem is unfortunately for me I cannot walk far as I would like. I have recently been ill.
What trams stop near or go rear to. From Central station.
Your advice is much appreciated.
Travel in and around the Dam
CHELSEA_SMOKERS_SOCIETY
Re: Travel in and around the Dam
all of them.DERICK wrote: What trams stop near or go rear to. From Central station.
the locals may disagree, but from a tourist point of view (thats you and me), everything you need is well with the borders of the map on this site.
all tram lines start, finish or pass through central station. theres tons of tram stops immediatly out front. from there you can get to and from anywhere you need.
by a day ticket, and you can use them as much as you want.... easy.
Trips to the 'dam: 27
Most tram stops have good clear route maps as well so it is pretty easy to work out which tram you need to get to your destination. If you think you are going to be using the tram a couple of times it is well worth grabbing a 'strippenkart' as it is much better value and makes it easy to jump on and off trams.
You can plan out your tram, metro and bus trips by visiting the GVB website. Peace.
Cannabis is The Tree of Life
