ive had a crack at growing a couple of times, with reasonable results.i kinda understand the drying/curing process and i always gave my harvest a decent amount of drying time.
(please correct me if im wrong) the reason for drying properly, as i understand it, is so that the chlorophyll (??) dies away, taking with it, the smell/taste of vegetation, and leaving the nice weedy smell/taste we all like.
so...
i got a bud recently, which was still very wet, and clearly has been pulled straight off a plant, which hasnt been dried/cured.
the smell of vegation (that fresh cut turf smell), is still very prominent despite the fact ive been drying the bud at home on a ledge ontop of a radiator, and is pretty much dry enough to smoke now
is there anyhting i can do ? or should do next time i get a still wet bud? to rescue the smell/taste... or is it doomed, because it was plucked to early?
yours truely,
regards,
RSVP,
toodle pips,
CSS.
wet weed
CHELSEA_SMOKERS_SOCIETY
Drying.....Copied from a growers forum
Living marijuana leaves are 80 percent water; colas are about 70 percent water. Marijuana dried for smoking contains only eight to 10 percent water, or about 10 percent of the original amount. There are several methods used to evaporate water; these have little effect on potency, but can affect the taste, bouquet, and smoothness of the smoke. Generally, the slower the dry, the smoother the taste. Excess drying and drying methods that use heat will evaporate some of the volatile oils that give each grass its unique taste and aroma.
Grasses which are dried as part of the curing process usually have a smooth, mild taste, because of the elimination of chlorophyll and various proteins. Cured marijuana may also be a little sweeter than when first picked, because the curing converts some of the plant's starch to simple sugars.
Some grasses are tasty and smooth-smoking when they are dried without curing, especially fresh homegrown buds which retain their volatile oils and sugar. Many homegrowers have acquired a taste for "natural" uncured grass, with its minty chlorophyll flavour; such marijuana is dried directly after harvesting.
Slow Drying
Slow drying is probably the method most commonly used to dry marijuana. Because of the slowness of the dry, a slight cure takes place, eliminating the bite sometimes associated with quickly dried grass.
There are many variations of the technique, but most commonly whole plants or separated colas are suspended upside down from a drawn string or from pegs on a wall in a cool dark room, closet, or other enclosed space. A large number of plants may take a week or two to dry. The drying time for small numbers of plants can be increased (for a slight cure) by placing the plants in large, open paper sacks that have ventilation holes cut in their sides. The drying room should have no heavy drafts, but mould may form on the plants if the air is stagnant. If weather is rainy or the air humid, increase ventilation and watch for any mould. Plants should be dried quickly under moderate heat if any mould appears.
Many experienced growers prefer slow drying to curing. There is little chance of error with this method, and buds usually smoke smooth and develop a pliable consistency. Slow-dried ripe buds retain their delicious, sweet aroma and taste.
Fast Drying
The fast dry-method produces a harsher smoke than slow drying, but it is often the most convenient method to use. The plants are suspended in the same way as for slow drying, but the temperature in the drying area is increased to between 90 and 115 degrees, often by means of electric or gas heater. The drying area is kept well-ventilated with a fan. As the plants dry, they are removed from the drying area. By this method, plants in a tightly packed room can be dried in less than four days, but the exhaust will contain the deliciously pungent odour of drying marijuana.
Indoor growers often hang plants to dry over radiators or stream pipes. Leaves are dried by placing them on a tray over a radiator or on top of the light fixture.
Marijuana that is fast-dried retains its original green colour and minty taste.
Oven Drying
Oven drying is often used by gardeners to sample their crop. Small quantities of material can be quickly dried by being placed in a 150 to 200 oven for about 10 minutes. Larger quantities can be dried in trays that contain a single layer of material or in a dehydrator. Oven-dried and dehydrator-dried marijuana usually has a harsh taste and bite, and loses much of its bouquet. The method is often used to dry marijuana which has been cured and dried but is too moist to smoke, or to dry marijuana which is to be used for cooking or extractions. It is an adequate method for obtaining dry material for testing and emergencies, but the main harvest should not be dried in this way. Oven drying works best with leaves. When leaves are dried together with buds or shoots, remove the material from the oven periodically, to separate the faster-drying leaf material (before it burns) from the slower drying buds. One way to do this is to place all the material on a wire screen over a tray. Every few minutes rub the material across the screen. Dried material falls unto the tray and is removed from the oven. Repeat until all the material has dried.
Oven curing works well when closely watched. Dried marijuana that is left in the oven will lose potency quickly. Any time the marijuana begins to char, most of the potency will already have been lost. This should not be a problem unless you are careless, or allow the temperature to go above 200 degrees.
Sun Drying
Some growers dry their crops right in the field. There are many methods of sun drying. In Oregon, some growers break the main stem about two feet from the ground. The leaves and buds dry gradually, since they are still partly attached to the plant. Other growers spread burlap and cover it with plants left to dry. Fan leaves are left on the plants to protect the drying buds from the sun. The grass is manicured after drying. Growers in Arizona shade drying plants with cheesecloth.
Sun-dried marijuana usually has a taste similar to that of oven-dried. Often the sun bleaches it slightly but also destroy some of the delicate bouquet. Prolonged exposure to the sun will decrease potency, although there is no noticeable loss if drying is done quickly.
Slow Drying
Fast Drying
Oven Drying
Sun Drying
Old School and Proud of It.
Hang in airing cupboard if you've harvested yourself, or place on Rizla papers on a plate in the airing cupboard if drying smaller bits of weed.
This works perfect even for wet weed you have bought, i do it all the time. I start smoking it wet obviously, but keep it in the airing cupboard, and it dries out over a period of a couple of days (we are talking a bought bag of fresh cut weed here, if your cutting yourself then you should be hanging it and will take a little bit longer
By drying it on the rizla's, some of the thc is absorbed by the papers (a very small amount) and makes them fun for rolling spliffs. I have a friend who used to deal, and he used to dry all his weed out on rizlas, then used to roll cigarettes with the rizla's. He never got stoned, but he was always happy
As was posted above, it's the chlorophyll that causes most of the issues. There is one other thing you can do to get rid of the chlorophyll taste, and that's a water cure, but that takes a couple of days and you still need to dry it after, so I recommend the airing cupboard route.
Just trying to be 'En Vogue'
The flavour comes from curing not drying, if you really want to make it flavoursome you'll need to store it (once it's dry) in an airtight container and burp it (open the container long enough to replace the old stagnant air with fresh - 30 mins a day is usually enough) this needs doing for at least 2 weeks but the longer the better.
Edit: Airing cupboards aren't very good for drying, the temperature needs to be constant not up & down, the airing cupboard also gets too hot.
My airing cupboard never gets too hot, in fact, i am sitting here in my bedsit, with the oil radiator on full, and I am still cold. I have several layers of clothing on, and the water has been on, and my airing cupboard is still only slightly warm. Obviously if you live in a modern efficient house, the airing cupboard may not be an ideal spot, but it's absolutely perfect in my placeBoner wrote:The flavour comes from curing not drying, if you really want to make it flavoursome you'll need to store it (once it's dry) in an airtight container and burp it (open the container long enough to replace the old stagnant air with fresh - 30 mins a day is usually enough) this needs doing for at least 2 weeks but the longer the better.
Curing
Copied from same growers site
how to cure your meds
by DJ Short Breeder of the famed "Flo" and "Blueberry" strains
Proper curing can exponentially increase the quality and desirability of your harvest. The key word to remember is "slow".
Dark & Dry
After cutting the plant or branch, hang it upside down in a cool, dry, and most importantly dark place. Light must be avoided from this point on. Leave the larger shade leaves on and they will gently droop and wrap around the plant, protecting the buds.
The time to the next step depends on how dry your hanging area is. This requires regular checking to determine when to proceed. When the larger shade leaves become dry and brittle to the touch it is time to gently clip them off.
Re-hang the branches in the drying room and regularly check them until the smaller leaves and bud tips become dry and brittle to the touch. It is then time to remove the buds from the branch and remove the rest of the leaf material as best as possible. This is what is referred to as "manicuring".
Now you have a few choices as to what to do with your manicured buds. The buds should still be a little wet at this point, especially on the inside, but the outer part of the buds should be starting to feel dry. Some of the buds, the smaller ones in particular, might even be smokable at this point.
If you are in a more humid area, or if the buds are still feeling heavy with moisture, you may want to try placing them on a suspended screen for a little while. This will help to hasten the drying process. Once again, regular checking to decide when they are ready for the next stage is crucial. This is also a skill that is developed more with time and experience, so practice!
Brown Bagging It
Once the buds are crisp on the outside but still moist on the inside it is time for the next step in the process: the paper bag. I like to use brown paper shopping bags due to their not being bleached, an unwanted chemical.
Simply fill a paper bag a few inches deep with the manicured buds. Don't pack the buds down and do not fold the bag too tight. A few small folds at the top of the bag, like a lunch bag, should suffice.
If the buds are a tad wet or if humid conditions dominate, you might want to consider cutting a few small holes in the bag, above the level of the buds, for ventilation.
As with proper manicuring, regular checking is key. The bags should be gently shaken, ever-so-carefully turning the buds, at least once a day. As the buds dry they will naturally compact into the self-preserving state that we all know and love. It is at this time that the buds can be more compacted together and the bag folded down tighter. They should now be fully smokable, though perhaps still slightly damp at the core.
The entire process, from harvest to these first smokable products, should take anywhere from two to four weeks, depending on your climate. Extremes in climate, such as very arid deserts or tropical humid areas, may take more or less time. There is no substitute for consistent, hands-on checking.
The Final Stage
A final curing stage, preferred by most connoisseurs, involves sealable jars. The nearly ready buds are transferred from the bag to the jar, packed in very loosely, and the jar is sealed. It is very important in the early jar-stage to check the buds at least once a day.
I like to dump them all out of the jar and gently fluff them up at least once a day at first, then less often as time progresses, usually for a week to ten days. It is important to be as gentle as possible so as not to damage too many of the resin glands. After a week or so all I do is simply open the jar and check the buds on a daily basis.
Watch for Mold
The main thing to watch (and smell) for throughout all of the curing process is mold. Whenever mold is found it must be dealt with immediately. The moldy bud needs to be removed, and the rest of the product needs to be exposed to a drier environment for a while.
The simplest solution is to go back one step. For example, if the mold was detected in the jar stage simply put the rest of the product back to the bag stage for awhile (after removing the contaminated product from the batch). If the mold is detected in the bag stage, go back to the screen. The screen is the driest process that I know of. If problems with the mold occur prior to this, a dehumidifier in the drying room may be the answer. Aside from watching and smelling for mold, always remember to keep the product in the dark.
Ready to go!
A bud is completely dry, cured, and ready for sale or consumption when the stem in the middle of the bud snaps when the bud is cracked with the fingers. The snap is easy to detect with practice. It is at this stage that the product can safely be sealed and stored for an indefinite period of time.
The longer you can stretch out this process, while also avoiding mold, the better. I like when it takes six to eight weeks from harvest to the finished product. You will be able to detect the fragrance of the product becoming more and more desirable as time progresses.
CLICK
Dark & Dry
Brown Bagging It
The Final Stage
Watch for Mold
Ready to go!
CLICK
omfg...copy some more text,,,hang till the braches snap,put in a jar,open once a day for a couple minutes and its done in 2 weeks...thats it..easy and not all those useless words..enjoy yer dry smoke....yer method is fine SR...everyone has different conditions,,,thanks for the over research there..lol..you go and wait 6 weeks..ill be stoned
- puffpuffgive
i find putting small amounts in a brown paper bag, folding the top lightly, and leaving in a dry, dark place around room temp usually works (will take a couple days to dry)
I fooking hate it when people sell wet bud to make more money
ik hou van amsterdam
