HI
- GroverDill
- GroverDill
Re: Smokeless Pipes?
This vaporizer works really well once you get the hang of it and it is really inexpensive. Produces little to no odor.GroverDill wrote:Can anyone recommend a specific pipe or way of smoking that lets off the least amount of smoke as I want to keep the smell to a minimum? Thanks for any helpypu can provide.
http://www.dominizer.com/
- GroverDill
they are available, a volcano is around 600e, ebay can save you a few euro. there are cheaper vaporizers available but you are still looking spending a some bucks.
if its only smell you are worried about, open the window, put a towel at the bottom of the door, run the shower, put a plastic shower cap over the smoke alarm (just in case), only use a small one hit pipe, take small hits, hold it in as long as possible, blow smoke out window, if unable to do that, put some dryer sheets in a card board tube (toiler paper roll) and blow the smoke thru that.
