advise on extraction/filtration kit using a 400watt light
howden01
Post by howden01 »
hi all need some advise for extraction/filtration kit using a 400 watt light what would be the ideal size of kit i need 100a1,125a1 etc cheers :roll:
100 growell or other similar shops have kits you can buy
http://www.growell.co.uk/p/0231/GroWell ... -Kits.html
Ghost
Post by Ghost »
Get a small 4inch intake fan, spigot fans are good for this, with ducting on into room. Use a 125a outtake and that will be adequate for this, also put a small oscilating fan in to circulate the air in the room.
Have your 4inch on the opposite side of the room to your outtake, but not inline with each other, and have your oscilating inbetween.
Hope this helps a little, this is more than enough for a 400w Son.
