Bad turbulence to AMS?
Big C
Post by Big C »
Basically I'm asking if anyone here on the board has ever had any bad turbulence on flight to Amsterdam
or anywhere. That's the only thing that worries me going to Amsterdam. Flying. I can't get hold of any
valium, and my tummy + alcohol doesn't mix well with the ups and downs of the plane.
There was a story in the news today about an Aruba to Miami flight that experienced bad turbulence
and it gave me the jitters :( since I will be flying in just a little over two weeks.
Anyone have any advice on just calming your mind before your flight?
gettingrimey
Re: Bad turbulence to AMS?
Post by gettingrimey »
I know this might be an idiotic thing to say but flying is one of the safest methods of getting around especially if you using a reputable airline with a modern fleet of aircraft. Also pilots have use of radar so will actively avoid weather systems. Iv flown hundreds of times and the worst turbulence for me has bee around south east asia, the whole of the plane glowing white cause of lighting flashes, its pretty intense, but its still very safe and thats the best thing to remember. If your flying from the states to Europe you should be fine and if you do encounter turbulence remember that its not going to bring the plane down.
I be chillin on the beach in the South of Venice
Or merking the President live on Channel 7
Dave J
Post by Dave J »
I can sometimes get nervous flying to, so sort of understand how you feel. For me when or if I start to feel nervous for whatever reason I try to make common sense kick in by looking round at the other passengers. The common sense being if whatever making me nervous is not notable on any other passenger then all is fine and its just me. Sort of works in my case to a point.
XANAX
Post by XANAX »
Big C wrote:Basically I'm asking if anyone here on the board has ever had any bad turbulence on flight to Amsterdam
Maybe a little science behind the reason for turbulence will put your mind more at ease.
As scary as it may appear, turbulence is not dangerous to the aircraft or the passengers who have their seat-belts fastened.
Different types of turbulence come from different sources, but what you are probably referring to is "clear air turbulence" (CAT) which is commonly encountered during high-altitude cruise flight. Other forms of turbulence are generated from thunderstorm activity where the aircraft transitions through a series of updrafts and downdrafts, creating turbulence. Departures on hot summer days will also create another type of turbulence which is more ground-based and derived from convective updrafts resulting from the intense heating of the surface. This heat is radiated upward and at low altitude, it comes across as turbulence when flying through this coulmn of rising air. Cooler adjacent air moves at a different rate and the juxtaposition of these rising and sinking or unequal columns of air, give rise to turbulence.
Clear air turbulence, encountered at high-altitude is associated with the jetstream. The jetstream is a narrow band of meandering air and located in the vicinity of the tropopause. The tropopause is the atmospheric division between the troposphere and the stratosphere. At this division, an abrupt change in the temperature lapse rate occurs. Temperature changes result in pressure changes and subsequently changes in the local velocity of the air. This is CAT. Wind moving at different speed/vectors will shear and create an instability in the air. Since aircraft often cruise in or near the jetstream (to take advantage of the tailwind), CAT is a possibility.
However, even though CAT can not be painted on RADAR, aircraft crossing the "Pond" follow one of a few specific flight tracks are essentially lined up one behind the other. Since these aircraft are following the same track and altitude, they issue "ride reports" which provide observed flight conditions. These reports are then passed along to the trailing aircraft and new altitudes are issued to avoid any expected areas of turbulence.
At any rate, turbulence can be avoided and it often is, without the PAX even knowing. Occasionally though, it is unavoidable for whatever reason. Usually at lower altitudes, where CAT can still be an issue (and not associated with the jetstream), ATC may not be able to accommodate enough diversion or the flight crew chooses to continue through the small area to expedite the flight, especially when its only light turbulence. I forgot to mention that turbulence comes in the following forms:
Chop
Light
Moderate
severe
Extreme
Most PAX have only experienced light to moderate.
Getting to the aircraft aspect, the aircraft is aerodynamically protected from structural failure during turbulent encounters. In a nut shell, the proper airspeed will provide this protection. When turbulence is encountered, a "turbulence penetration speed" is adhered to. This allows the aircraft to fly safely through the air without damage. This is a function of how the oncoming or 'relative airstream" hits or curves over and around the wing. At lower penetration speeds, the wing angle is greater and should too strong a gust "attack" this wing, it will "aerodynamically stall" before "snapping off." A stall is just a loss of lift on the wing. To maintain level altitude, a wing requires to produce the same lift as weight. If the AC weight is 200 lbs., then the wing must provide lift equal to 200 lbs of lift. In a "stall" wing situation, there is less than 200 lbs of wing lift being provided, so lift is lost and a slow descent occurs.
Anyway... hope you feel a little safer about those Pond crossings!!!
BTW, cant you just get your doctor to write for some valium or xanax? Tell them youre doing a long overseas flight and get panic attacks, anxiety, time diff in sleeping, etc.
You can't predict turbulence. Have a big meal at home and it will knock u out on the flight.
Yep had awsome turbulence on a trip to Dam :wink:
dr'gonzo
Post by dr'gonzo »
I'm interested to know why you should have difficulty in obtaining a drug that's widely accepted to aid the alleviation of specific anxiety?
I don't have any objection to flying but I wouldn't dream of getting on a long haul without 5mg diazepam followed thirty minutes later by a vodka and tonic or three. It's such a great excuse to get fucked.
USbongLord
Post by USbongLord »
Couldn't care if the plane did loop dee loops tha whole way ....I'm going to amsterdam :mrgreen: oh and 23 bong hits should be fine for a 6 hour flight
Willjay
Post by Willjay »
24 bong hits would be mathematically more appropriate :mrgreen:
www.stopthedrugwar.org
www.mpp.org
www.drugpolicy.org
matty223
Post by matty223 »
smoke a dub, take Valuim get on the plane and dont worry
