Best method for light weight
I've already read some very good advice for light weights like me: eat first, drink a coke (or other caffeinated/sugary drink), take it slow, stick to Sativa strains
My question is, what's the best way to partake without getting too blasted to enjoy myself? I'd like to get high but still enjoy the day.
Would you advise?
1) Vaporizer
2) Bong
3) Pipe
4) Joint
5) Pre-rolled joint w/ tabacco (and do they still have those since the anti-smoking law went into effect?)
6) Hash, space cake, or some other method I didn't think of
What's the best way to control your intake and keep yourself from overdoing it?
Thanks for the advice. I'll be there for my first trip in less than a week!
Would you advise?
1) Vaporizer
2) Bong
3) Pipe
4) Joint
Re: Best method for light weight
take it slow.. However, I had not been smoking before my first trip last fall, and it took a true power smoke session to get to me.. ( spoon and multiple huge joints) and i didn't realy try any isolators per say.. ( tasted a few in joints) .. the edibles can be strong and have more of a long term effect where as smokling gets you high quick and only lasts a few hours.. edibles take longer to work but keep you high much longer. Hash is great, but i have never been around enough of it to get used to smoking it . enjoy, take it slow, but don't be a total pussy about it.
Living The Dream...
I'd say it's not so much the method of consumption, but the amount of weed (and/or hash)
Best advice really is to take it slow. See how the dutch weed works for you and you'll quickly learn to get the amount right. Make sure to keep hydrated and your sugar supply up and you should be fine,
Remember you're not trying to prove anything to anyone
- StillSmokin
I think I'd advise staying away from the pipes/bongs/vapes at first - that is unless you don't normally smoke tobacco - then they might be a good idea, it's too easy to load a spliff up if you're going to smoke pure. If you do normally smoke w/ tobacco, just put a smaller amount of weed in than you would normally do, when I first started going to the Dam it'd take me about 3 days before I could handle rolling them pure, would normally start off with 30% weed / 70% baccy, then slowly to 50/50, 70/30, then pure.
Definetly advise against hash cake to start, as they can be quite heavy stoned, take a while to start to take effect (so can be a bit deceptive esp if you're smoking also) and also probably last the longest.
The strength is a really odd one, and also affects different people in different ways. And also whether you prefer the "high" or "stoned" feeling. Best advice can think of is to stick to 1 or 2 strains to start, just to smoke a small amount of whatever you end up deciding eg smoke 1/3 of the joint, wait 10/20 min before smoking another 1/3rd, then after another 10/20 you'l probably start to figure out the strength and whether you need more or less in the next joint.
Can't say I've ever tried a preroll - so can't help with that one, but if you can roll, then best off knowing exactly what's in it imo.
I suggest going at it slow also.
Don't burn yourself out, it's no fun to be a space cadet sleeping at the shop. lol
I'd suggest a Sativa, just because of it's energy giving qualities. Smoke a J to start.
Personally, I don't suggest mixing with Tobacco, as tobacco is the devil. lol
Start with a few mid-sized j's and enjoy!
Or, you could go all-in, and try something like a Frosty Mug.... though it would be hard to find a place to set that up for you.
(If you don't know what a Frosty Mug is, I am happy to start a thread to show everyone... it's the best)
- Snake Pliskin
Drag your ass over to the Warmoestraat and pay the 3rd dark haired Ukrainian wench you see in a Red room to smoke a joint with her pussy and then blow you the smoke rings...
staggerlee
USBONGLORD wrote:Straight up 3 liter gravity bong hits![]()
Snake Pliskin wrote:Drag your ass over to the Warmoestraat and pay the 3rd dark haired Ukrainian wench you see in a Red room to smoke a joint with her pussy and then blow you the smoke rings...
Rusty Shackleford
Roll a joint, don't chug the life out of it, take it slow and just chill
KEEP ER LIT
Bar of chocolate (75 grams ish), half a gram of haze in a pure (don't use tobacco unless you do day to day in the first place) joint. Can of coke and light up. Take an hour on that first joint having short breaks each time you feel the hit. Get yourself a second coke if you still have any joint left after the first coke.
Then take a break for half an hour to an hour and go take a walk and perhaps a little food. Job done, you will have set yourself up for your trip. After the first joint just go at your own speed you'll be surprised just how much you'll be able to smoke after the first couple of joints. I don't really smoke at home yet after my first couple of joints I got well into it and did a good 30 odd grams or more in just 4 days. Not bad for a light smoker doing near all haze strains.
Go to voyagers,grab the three foot tube that looks like an artillery shell from the back,stuff a gram of blueberry power plant in the hitter and snap a 3 foot wall of smoke...should get ya over the hump right quick I recon
...when you regain consciousness it should be sometime the next day,everything else should be easy after that
USBONGLORD wrote:Go to voyagers,grab the three foot tube that looks like an artillery shell from the back,stuff a gram of blueberry power plant in the hitter and snap a 3 foot wall of smoke...should get ya over the hump right quick I recon...when you regain consciousness it should be sometime the next day,everything else should be easy after that
I'm terrifyed by the thought that this bit of wisdom might actually make sense!!!
- TwoCanucks
Might as well go in both feet first, that way you'll shed them "light weight" floaters and start swimming in the shark infested waters.
- geekymonkey
If you don't smoke tobacco, then pick up a small glass pipe- that way you can smoke small bowls of hash or weed (or mixed) without knocking yourself out.
