NYC to JFK ?
Getting there and getting around.
Willjay
NYC to JFK ?
Post by Willjay »
Does the sky train connect directly to JFK from Penn Station?
www.stopthedrugwar.org
www.mpp.org
www.drugpolicy.org
worldcitizen1723
Re: NYC to JFK ?
Post by worldcitizen1723 »
Last time I did it (at least a couple years ago) you had to take a bus to the sky train. Probably could also take a subway and transfer at the Jamaica station. Maybe someone else has done the route more recently....
Willjay
Re: NYC to JFK ?
Post by Willjay »
Thanks for the reply. Thought I saw a poster for it during one of our pup crawls through manhattan, one connection from manhattan to JFK would be nice.
www.mpp.org
www.drugpolicy.org
ed the head
Re: NYC to JFK ?
Post by ed the head »
It does NOT.
You have to take the A train to Howard Beach and transfer upstairs, through $5 turnstyles onto the Airport Loop train.
The Loop train is free on the return trip to NY
Hope this helps
Willjay
Re: NYC to JFK ?
Post by Willjay »
Thanks Ed, I think I can take the LIRR to Jamaica sta and PU the air train there as well
www.mpp.org
www.drugpolicy.org
worldcitizen1723
Re: NYC to JFK ?
Willjay wrote:Thanks Ed, I think I can take the LIRR to Jamaica sta and PU the air train there as well
Yup
That'll work
Thanks Ed
For confirming the sad truth that the advertisements are misleading
gronin
Re: NYC to JFK ?
Post by gronin »
Hate to point out the obvious.... The MTA site has a subway map including the Skytrain, LIRR at http://www.mta.info/nyct/maps/subwaymap.pdf
You can indeed get the LIRR to Jamaica Center or the subway to Jamaica/Sutphin Ave. (same place but underground)
ed the head
Re: NYC to JFK ?
gronin wrote:Hate to point out the obvious.... The MTA site has a subway map including the Skytrain, LIRR at http://www.mta.info/nyct/maps/subwaymap.pdf
Exactly, thank you. LIRR will exact a $ premium vs subway but will be faster and more comfortable.
matty223
Re: NYC to JFK ?
Post by matty223 »
also right outside Grand central terminal (park & 42st) you can get the bus too Jfk if you wanted to do that, and Cabs have a set price from Manhattan to JFK
Peace Matty
gronin
Re: NYC to JFK ?
Post by gronin »
matty223 wrote:also right outside Grand central terminal (park & 42st) you can get the bus too Jfk if you wanted to do that, and Cabs have a set price from Manhattan to JFK
Peace Matty
$45 flat rate for cab or $2.20 on the subway last time I was there. Subway for me but I'm just naturally cheap...
worldcitizen1723
Re: NYC to JFK ?
Flat Fare from John F. Kennedy (JFK) Airport:
For trips between (to and from) Manhattan and JFK International Airport, the flat fare is $52.00 plus any tolls using Rate Code 2 on the meter. A NY State Tax Surcharge of $.50 will be added to each trip.
If passengers request multiple stops, the flat rate of $52.00 will be collected at the first stop in either Manhattan or JFK International Airport, and the meter will be activated at Rate Code 1 (standard city rate) for the remainder of the trip. The metered fare should be collected at the last stop, from the last passenger.
All trips between JFK International Airport and New York City destinations other than Manhattan will use that standard metered rate.
*you will pay extra for baggage too
usually ends up at $65.00
matty223
Re: NYC to JFK ?
Post by matty223 »
i live in westchester i thought it was cheaper then that, since i pay 65 dollars to come here right over the bronx border
worldcitizen1723
Re: NYC to JFK ?
matty223 wrote:i live in westchester i thought it was cheaper then that, since i pay 65 dollars to come here right over the bronx border
No not cheaper
unfortunately.
