Any plumbers in the house ?
Moderator: Balou
- Von Goat Weed
Re: Any plumbers in the house ?
Yes! im a man of all trades
135$ to come look at problem 65$ an hours is the price
Trying to do some routine maintenance and change the tap (faucet?) washers , turned off the stopcock under the sink , it's turned my water off in the Kitchen but not bathroom !!!!?? Wtf ?
I'm thinkin either outside stopcock , or need to run water for a while to drain tank ? (Live in a flat)
- Von Goat Weed
You have to close the Main valve (stopclock) it's usually the one whit pipes going to your water tank or boiler
Read above iv done that , it has shut the water off in the kitchen but not bathroom
My last two houses have both had there own stopcock in the bathroom buddy, both times was a bugger to find as hidden behind panelling though , i hope its not a fully tiled room if its the same for you, mine were between the bog and the sink both times
Trips to Amsterdam 50-Trip 51- April 2018
Mmmmmm it is boxed in but I will be able to have a look cheers man
- Willjay
Good luck, every one wants indoor plumbing nobody wants to see the pipes
www.stopthedrugwar.org
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- Von Goat Weed
Cisco wrote:Read above iv done that , it has shut the water off in the kitchen but not bathroom
Mmmm I did!! I'll tell you in other way !! The valve you closed aint the main water line connected to the main pipe to your water tank..., you not in America I'm guessing? Good chance like other said it hiden if not visible... Good chance is connected to you tub in bathroom!
Best way to find out call a Plummer
Your right I ain't in America and why would I phone a plumber when I can potentially do it myself ? Also the engineer I just had in my house told me it's the main stopcock as it's coming directly from outside , so I'm presuming now it is possibly a case of me being a bit more patient than running the water for 2mns lol (to empty tank)
- Willjay
Now you know why we charge by the hour.Cisco wrote:Your right I ain't in America and why would I phone a plumber when I can potentially do it myself ? Also the engineer I just had in my house told me it's the main stopcock as it's coming directly from outside , so I'm presuming now it is possibly a case of me being a bit more patient than running the water for 2mns lol (to empty tank)
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- Von Goat Weed
Simple! Take a chance and start destroying the wall around your bathtub good chance to valve is behind that wall.. If pluming is anything like ancient Americans (pre 60's 70's) < also walls were different at the time so you find a wall of cement 1-2 inches since they didn't have jiprock back in the days if others built pre 30's good chance you'll find wood walls behind.
So start destroying your wall
just get a Plummer he got the tools to find pipes
be easier and less of a problem .
Good luck
Good luck
- Willjay
job is not done till the paper work is complete, how did you make out
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
