"best" filler for hash?
aVeryOldLady
Hi guys,
as I am a joint smoker all the way, I like to smoke my hash in joints as well. Therefore I need weed as a filler. I usually don't take weed with a high potency as it would only overshadow the effects and the taste of the hash.
Last time I got a lot of Durban Poison from CS Black Star (2.7g for 10€) and also the Ghanaian Sativa (same price).
My question is: Is there any place that has weed with as little effect and taste of its own to it as possible, while still maintaining a smooth smoke with a (relatively) good quality?
Then, there is also the problem with some of those fillers being rather uplifting, while others are sedating. Thus, for example mixing my Durban Poison with a calming hash, I think that also affects the effects of the hash. Unfortunately, I mostly see "Thai" or the Sativas already mentioned.
I've seen a couple of places having nice deals. For example Club Media with 5g Thai for 17,50€, Popeyes with 5g Weed Mix for 20€, and the Bulldog with 3.5g Jamaican for 12€ and 3g Thai for 12€. Has anyone experience with those?
Re: "best" filler for hash?
I have similar problem, I don't use tobacco in my weed joints but still have to use it for hash which pisses me off tbh, tried same route as your taking with the lower end gear but it just don't appeal to me and I just don't enjoy it if I am honest, bong or pipe the hash again it's just not the same enjoyment as sucking on a nice hash cone IMO.
Now if they did a decent tasteless tobacco substitute I would be in heaven, the stuff they have on cs tables is terrible.
- Willjay
maybe you guys are looking at it the wrong way
try getting the best most tasty bud and mix that with the hash and have a go
what the hell your in Amsterdam
www.stopthedrugwar.org
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
aVeryOldLady
I'm careful with those substitutes, I'm never sure what it actually consists of and what happens if you burn that stuff. I tried in on a couple occasions, and as you said, it burns badly and usually tastes so as well.
aVeryOldLady
I actually do smoke a lot of flower when I'm there. But sometimes I'm in the mood for some nice oily, spicy hash with thick smoke. I don't prefer doing it this way because, as you imply, the bud itself will have a distinct flavor, which may lessen the experience of the hash.Willjay wrote:try getting the best most tasty bud and mix that with the hash and have a go
Some of the cheaper oldschool strains are generaly tasteless in adam,
a bag of snowwhite from bestfriends could do the trick, its cheap
a 5gr deal at greenplace, oldschool strain for 40€.
Otherwise i would try some of the outdoors you can find in town (the sunshine in club media for 6€ gr, bio and purple in katsu or try some yoyo's outdoor)
In central coffeshop you can find cheap strains too, i remember peacemaker was nice for filler last year.
I find all thoses option a little better then mixing with thai bud
hope it helps
hope it helps
aVeryOldLady
Thanks! Will check out those options too
http://www.coffeeshopmenus.org/het%20Ba ... eedMan.jpg
Might want to give the last 2 a try. I myself love the white baloon and won t ever go for some other indica elsewhere while this batch still stands cuz the price is too good!The bio baloon looked pretty good for an outdoor so it might not do the trick...
- redeyezman
Fuck filler. Hash under glass method. Old school it up.
otherwise...
Vanilla Kush and King Hassan is a spicy/sweet combo sure to give pleasure.
otherwise...
Shells sink. Dreams float.
Still nowt here for me
I would rather enjoy most these strains on there own, even if they are tasteless strains they will still carry something over that will mask the real taste and effect the hash alone will give.
Guess it's stick to the bud and bong the hash
I'd have a look at CS Paradox's outdoor strains "Bio Green" and "Purple". Way better than shitty Thai, but weak enough to not really effect good hash.
Tastewise, I'm the last person to ask, since every strain basically tastes the same for me for whatever reason.
I like Solo's Galantus (outdoor) as a filler , €33.75/5gs , I do usually grab a little pipe every trip to though , little round of hashpipe lovely , have fun whatever you go with
aVeryOldLady
Picking up a hashpipe sounds nice as well
Thanks for all the advice !
agree with a previous poster. I do the same with hash and mix it in a spliff with weed - I use the bio from paradox. It has a small amount of taste but its uninhibitive to the hash and its also quite cheap too.
Bio from Paradox is indeed good for a cheap filler. And it's actually a decent enough outdoor in in its own right.
If I really wanna have low-thc for the hash-effect profile to shine, then I use ABV in place of baccy (already been vaped weed) which seems to do the trick easily enough - if you vape a lot it ends up being hella cheap to self-supply as well.
