DeLekkersteNUGS16 wrote:I'll try like hell to make this my one preachy bit at you –
I'm not sure whether you've done this M.O. before or not, regarding a hair-analysis for drugs, but the bitch of hair-tests is that they're damn near impossible to beat without time and lots of it – several months I think at least, you should do some more research but even single uses stay locked into your follicle history for a good while, I believe. The problem with shaving all your body hair it's the equivalent of drinking your weight in water beforehand and getting an auto-fail because you pissed completely clear urine – or so I would imagine, also you still have hair on your head, no?
Now, if you have a urinalysis and follow your purported M.O. of occasional use, then occasional cheeky tokes over long sporadic weekends should be fine, assuming you have an at least slightly above average metabolism. This is because THC only accumulates long term (detectable through urine) with chronic consecutive use. If your system is clean and you smoke once, you should only have to wait a few days for it to flush itself out, and then you can rinse. repeat.
Anyway, that's just my two cents on the matter, I may be missing a crucial piece of information regarding your situation though, anyhow good luck, enjoy Amsterdam and welcome to ACD!
Hi, I did a little homework but I could be wrong.
My understandings are the hair grows at half inch a month, the thc you ingest now is scalpside after around 7 days. They can only test so far back as your hair length, half inch a month, like tree rings and climate changes its down to when within the given length of hair. They break it down , the whole strand length and test it singularly and results are like" hey, you got wrecked at some point", rather than, " hey, you got wrecked 47 days ago. So, I'm thinking I'll probably give it 7-14 days back in the uk before I look like a lab animal.
What's your thoughts?
If I wasn't this discrete, I'd be destitute.
