Take out coffee shops
Evening guys,
My wife and I are flying into Schipol in May, we will be popping into Amsterdam to get some lunch and weed before we pick up our rental car and head to Putten were we will be staying, the question I have for you is where is a good shop with a good selection not too far from the train station that I can just pop in and pick up a couple grams? We don’t want to sit in a shop and have our clothes stinking of weed before we pick up the car as this may not go down too well!
Thanks in advance for any guidance you can provide!
- OneHighMofo
Re: Take out coffee shops
Voyagers is almost bang opposite Central Station at the northern tip of Geldersekade. It's a forum favourite and unlikey to let you down.
Have fun!
Have fun!
- Willjay
Central Coffeeshop is a fly and buy now if your really worried about picking up orders
www.stopthedrugwar.org
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
choppermike
If Central and Voyagers haven't got you stashed up (which I doubt ) Het Gelderse is another 75 metres down the left side of Voyagers on the right. Check the ACD map.
.. in the avoid curve
- notsofasteddie
All of the above are good choices, but depending on how much time you have there are lots of other options that are pretty close.The ACD mapchoppermike wrote: ↑Wed 21st Mar 2018 11:21 pm If Central and Voyagers haven't got you stashed up (which I doubt ) Het Gelderse is another 75 metres down the left side of Voyagers on the right. Check the ACD map.
Explore Coffeeshop Menus! Let your fingers do some Menu walking! You might find something special.
Thank you FBN!!
Thanks guys, I just wasn’t sure of the etiquette, so most shops let you just walk in pick up and leave? Thanks again!
Yup by and fly is part and parcel of Amsterdam life
- OneHighMofo
All great suggestions by the ACD massive
If you come across the acronym B'n'F or similar while perusing this lovely site - that means Buy and Fly. An important part of Dam life as our good friend Devore points out above
Thanks for all your suggestions guys!
I’m glad I now know what FnB stands for and that I know I can do just that!
No problem buddy. Hope you have some good luck in your purchases.
I Buy and Fly quite often as I like to sit by the canals and chill. I'm not a fan of Central as I've had too many bad buys but Voyagers round the corner is probably the best buy and fly in the Centraal Station area.
Dev
Dev
The Stoned Shaman
Yeah I recommend flying and buying from Voyagers. I picked up some tasty Fromage Blue from there a few weeks back and I’m happy to report it did the job to.
All the best with your purchases
You guys are a fountain of knowledge and I appreciate all your suggestions.
Can’t wait to try a few different flavours!
Nick
Nick
I’ll probably just pop into voyagers as we only have a few hours, the wife wants to get some lunch as well in that time.
Whilst she’s planning where to go and what to see, I’m planning on the perfect choice of Coffeeshop!
choppermike
Think you need to investigate "BATAVIA" - smoking room, top biers, top nosh, and it's only a canal width from Voyagers. When time is limited !¡!!
- OneHighMofo
Nothing like killing two birds with one stonechoppermike wrote: ↑Sat 24th Mar 2018 05:47 pm Think you need to investigate "BATAVIA" - smoking room, top biers, top nosh, and it's only a canal width from Voyagers. When time is limited !¡!!![]()
