Willjay wrote: ↑Sat 6th Jul 2019 08:52 pm
Or mix that hash with some full fat yogurt,
I used to heat it on a spoon with a little bit of oil to dissolve as much as possible then mix it into said yogurt, 30 mins in the fridge then down the hatch. Worked wonders!
Willjay how much hash do you normally use for the desired effect?
Thanks Mate.
I’m not that much of an edible fan but knew that the fat would help the THC into the blood flow. But if I were to do it again it would probably be a gram, however I’ve been at this for over 50 years I have an high tolerance. How much can you smoke in a day would be my reference to how much.
However I’ve recently meet an biology/chemistry person that works in our states medical marijuana program and have been missing a step of activating it with some heat. With that additional info I think I may try edibles again
instagram if you want anything worth while imo. paradox edibles were tasty as heck, but i ate one full one and 1/4 of my friends and (personally) felt no effect.
instagram @shooter_mcdabbin
Solution was 3/4 gram Rookies iceolator in full fat yogurt. Took about 1.25 hours to kick in on an empty stomach. It delivered many hours of blissful nodding in and out.
BTW if you have not see Rookies since their renovation check it out. Utterly fantastic.
Lafe wrote: ↑Wed 17th Jul 2019 04:23 am
Glad you had a good time. just curious did you heat the hash as shaggy suggests?
I did not. I will try it next time, it seems reasonable.
That’s the one thing I learned from the chemist from our state medical marijuana program said, that you need to activate it, I always thought that the pressing of hash was enough, I was wrong might of been your body heat that actually activated it that’s why it so long to take effect. Keep on token
Seen a guy take couple grams of hash an put in baggy and tied it shut .Then ordered tea with tea bag on the side . The gave him hot water in one of those steel little pots with lid flips up. He sat the baggy in the hot water .We smoked a couple joints ,then he ordered hot coco heavy on the cream .When the hot coco came he took the hash out of water and into coco .....after taking out of baggy If you have access to vac-pac machine you can use weed or hash ,after sealing boil in pot of water for one hour ...she,s activated
